Question about Brother HL 1440 Laser Printer
Got 3 black (gray) lines on my HL-1440 printer every time I print a page. Have replaced the toner cartridge but still got the same result.
  • 1,218 Answers
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Apr 11, 2011
Hi, I have this type of printer and there has been no problems..except.. i'm the new secretary and the golden drum light is on..never noticed if it was or has been always on..and the printing every 1 1/2...
Means toner cartridge is nearly to end. Just shake a little bit to distribute evenly the toner powder and be ready to purchase new toner cartridge. And is it nothing to do with the drum. Drum problem will create black shadow lines when printing.
Dec 07, 2010 | Brother HL 1440 Laser Printer
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Jul 08, 2010 | Brother HL 1440 Laser Printer
Print quality is poor. I hace cleaned corona wire and poblem is still there. Entire page is streaked with black. White paper comes out gray. What else can I do? Should I change the toner cartridge?
If you have a old drum or old toner cartridge switch them and see if it goes away. Other wise start with a new toner cartridge. I sell them for 40.00 and the drum for 60.00. Steven 818-888-0006
Mar 06, 2010 | Brother HL 1440 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
Black smudging on all the page from hl1440-brother
  • Turn off the printer.
  • Take the toner off.
  • Shake the toner for 4-5 times.
  • Install it back.
  • Then try to print.
Thanks, CF
Jun 17, 2009 | Brother HL 1440 Laser Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Brother HL 1440 Laser Printer Logo
286 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
