Question about Frigidaire FRA256ST2 WallWindow Air Conditioner
I cant take the front and back off of the air conditioner so i can take out the shipping safety stuff. how do i take them off?
  • 413 Answers
The plastic front must come off. Usually the screws to take the front off are behind the front grille of the plastic front by the filter. The unit will probably slide out of the case when you get the plastic front off, but at times they will put a shipping screw through the back side of the case on a lower corner into the unit. This screw(s) will also have to come out.
Posted on Apr 11, 2011
How can I test to determine whether a failed A/C drain safety switch is wired wrong or is defective?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
I would love to help you with your problem but i need a little more information.
Air Conditioning West Palm Beach
May 06, 2015 | Heating & Cooling
How do i repair my dometic air con unit on caravan
When you say safety switch do you mean fuse or breaker? If your breaker is popping(110 volt) then if probably is your compressor overloading the system.i would do as advised before and remove shroud(cover on roof) and clean coils or fins with some otc coil cleaner. Ive been in the buisness eight years and only one time have i change a compressor. Most people get a new ac. Sorry for the bad news
Dec 26, 2014 | Dometic Rooftop RV Air Conditioner
Where can I get a double pole contactor for my goodman ckl60-1
I buy all of my contactors at www.grainger.com
Match up the coil voltage 24v
The number of poles 2
The contactor rating...in this case it should beat least 40 amp.
You can find them buy searching the site for "definite purpose contactor"
They are very efficient and will ship quickly from the closest warehouse...I usually have my stuff UPS the next day.
heatman101
Aug 25, 2011 | Goodman CLQ36AR49 Air Conditioner
Air conditioner mode 7024de-1 i was wondering where i can find the how to operate this unit it stopped blowing cold air was wondering if the kids hit the timer button or its just time for a new one so how...
check the coils front and back for accumulated crud and unplug it and wash it out real good untill they are clean, foaming oven cleaner is good stuff to use for cleaning before you wash it out
Aug 09, 2011 | Danby Heating & Cooling
I have a Goodman A/C unit model number AWUF36106BA and serial number 1010684384. It keeps shutting off on us and we have had a repair man come out and said the problem we had is the emergency shut off...
If the drip pan switch is shutting the unit down , this means you have a condensate drain issue. Be careful about wiring around any safety switch, especially if the furnace is in the attic or on a second floor. You could have water dripping on the ceiling. The drip pan switch is a safety switch. The best thing to do would be to inspect the furnace. The pan is underneath it. Look inside the pan if you can. If it is full of water, use a shop vac and vac the water out of the pan. If there is no water, you can locate the safety switch, take the two wires loose from it and just wire them together. Caution: This will be wiring around the condensate safety switch that could cause water to leak on the ceiling or floor depending where the furnace is. Don't go too long without getting someone out to clean the condensate drain out.
May 01, 2011 | Goodman CKL36AR36 Air Conditioner
How do you change the air filter for the Mitsubishi Electric Mr. Slim, Model #msh12tn and where can you buy them?
If this is a ceiling mount, there should be to slide tabs on front of the
unit, slide those back and the cover should come down, it has a couple of safety chaines to keep the cover from coming all the way down
Jul 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Maytag M3X05F2AK air Conditioner -BLACK CHUNKS FLYING OUT
remove front cover and clean the coils off with a nylon brush. make sure filter is clean. with front cover off take it outside hook it to an extension cord and set it on the floor. then let it run till the stuff stops coming out. if you want to open the whole thing up you could clean it out even more example being the inside fan area behind the coils, but the first option should work.
Jun 05, 2009 | Heating & Cooling
What kind of stupid "warrantee" is that?
This is why I ask if there is local warranty service for anything that I buy, especially if it is very heavy to ship.
To ship the air conditioner, you will have to get the proper box and packing. There are transport companies that will ship it for you.
You will find one interesting thing about shipping an air conditioner. Because of the size and weight, the cost of shipping will probably come to about the cost of servicing it by an independent refrigeration service center if there are no major parts involved.
When shipping an air conditioner you will have to ship it insured. If you don't insure it, and if it is dropped or smashed you will have no re-coarse to have any compensation for it. This will also add to the cost.
At my location here in Canada, DeLonghi has an almost local service. I once tried to call them, and they are very poor at answering the phone to respond to questions.
Jerry G.
Jul 01, 2008 | DeLonghi CF210 Portable Air Conditioner
Delonghi pac l90 air filter
Call 800-865-6330.  The white accordion 3M Filtrete filter is $37.95, and is NOT available on the Delonghi website.
May 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Frigidaire FRA256ST2 WallWindow Air Conditioner Logo
274 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
