Question about Panasonic SC-PT660 Theater System
I have a Panasonic SA-PT660 that won't power up. I had this problem on and off for about a year before it stopped working and I took it in. They said something about re-aligning the mechanism and cleaning it. It has worked for the past year and now it won't power up again. I took it apart and checked for loose cables and anything else out of the ordinary but don't see anything and it still won't power up.
ginko
  • 19396 Answers
SOURCE: Unlock Panasonic SA-PT660
I will see if there is any known hack for this model, some unit does not have any unlock procedure.
Posted on Sep 11, 2008
SOURCE: panasonic sa-ht700
Usually problems that start "out of the blue" after being powered-up for hours, caused by heat building up are due to things inside getting hotter and hotter until they fail. Unless something actually burns up, this is a reversible problem. Shut it down to allow it to cool off, and it works again. I own a SA-HT700. After 24 hours or so of being powered-on. it starts making a loud rumbling noise. Turning it off for 20 minutes fixes the problem. There's a fan on the back of the unit. It does not work. The heat sinks inside my unit are not covered with dust - suggesting the fan has never worked. I rigged an external DC supply to the 12V fan, so now the fan runs all the time. I am waiting to see if this fixes the problem.
Posted on Nov 20, 2008
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
  • 1121 Answers
SOURCE: Repeated F61 fault code on Panasonic Home cinema
fans dirty. clean-it with a soft small brush and vacuum cleaner
Posted on Feb 16, 2010
SOURCE: I start up my panasonic sa-pt660 and it makes a
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Posted on Feb 09, 2011
I had to replug things in for my dish and unit sat sidewards to get to plugs. It now says locked and can eject disc, select source. Help
Try this:
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
Dec 31, 2015 | Panasonic...
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
SA-PT660 service manual
I'm not sure if You're really looking for service manual or user manual. If You need the former here's link to one SA-PT660P service manual
Aug 06, 2012 | Panasonic Audio Players & Recorders
How and where can i get a new panasonic dvd for my home theather system. model number sc-pt660. the disk changer does not open and close.
Considering that this unit comes as a bundle it wouldnt be profitable for stores to carry the parts seperatly. The best bet here would be if it still is within the 30 return policy then to take it back to the store you purchased it from to swap out for another. Since Im sure this isnt the case or you would have already done this you can try to save a dime by searching ebay for part systems and repairing or replacing the problem part in your tray (specifically being the tray motor). Theres plenty of tutorials for similar products found on DIY.com. Heres a link...
http://cgi.ebay.com/Panasonic-SA-PT660-5-disc-DVD-player-SC-PT660-AS-IS-/370503039935
May 05, 2011 | Panasonic Televison & Video
Resubmitted: How do I resynchronize my 5 trays in the DVD player portion of a Panasonic SA-PT660. A manual seems unavailable or I would not have posted here.The only manual I have seen a clue to exists in...
  • Here is a manual that will server your purpose. It is not the exact same model manual to a 'T' but I looked it over real well and it is for your unit too. Your gonna go down to page 16. This is for a model SC-PT660. same unit really.
http://static.highspeedbackbone.net/pdf/Panasonic-SC-PT660-Manual.pdf
Regards, Tony
Apr 27, 2011 | Panasonic Televison & Video
I have a Panasonic SA-PT660. It is just over a year old...and I get the 5 Disk changer to open. I turn the unit on and it just clicks (sounds like machine gun) going off. It says Disk Changer Error....
Hi there
Q: Did you push the CD Door by force?
If yes ...
1: you have misplaced the mechanical wheels ..
or broke some thing.
2: Or the second possibility is that the Driving motor rubber is broken
the answer is to service it.
Good Luck
Hope this helps
Nov 19, 2017 | Panasonic SC-PT660 Theater System
Panasonic SC-PT660 Theater System Logo
1,129 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
