Question about Mitsubishi WD-62827 62" Television
I have a mitsubishi ws-62727 and after ten minutes colors go out and come in black and white
    Top Expert:
  • Mitsubishi Master
  • 75,424 Answers
Hello
Just look in the antenna connections and all other connections for any loose; and make sure that all are firm. All found alright and still the problem perists, try retune the TV once more. Tuneing drifts will make this kind of fault. If it was, retuning will solve the problem. Make it autotune. Still the problem is ther, tuner inside your TV is faulty, and has to be replaced with same typwe and number. OK.
Posted on Apr 11, 2011
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi rear projection
ok sir! maybe you have defective color crystal carrier! thats why your unit is in lost of color!
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
The color went out so that now it is black and white. If I turn off the tv for a few minutes it will go back to normal. Then after being on for a few minutes it will change back to black and white. If you...
This is unusual for this model, can you tell me what source you use for signal? Cable? Sat? Direct TV? Also how are you connected----via the coax fitting or the rear AV jacks.
Steve
Nov 01, 2011 | Mitsubishi WS-65809 65" Rear Projection...
The color is not working. The shows are in black
Your color wheel has gone out, or your video board is defective.
I'd check your cables, then listen to see if the color wheel is humming or winding.
Feb 04, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Color goes in and out
your red tube is trying to go out...
Oct 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Color is going weird
Chroma IC is to blame, but before you go replacing it, be sure that the power supply voltages are correct....accordianman
Jun 05, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws-a55 2003 model
this set has self diagnosis, try this first to get error codes. Look here or ctechnicians.com to get info
Dec 31, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Mitsubishi WD-62827 62" Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
