Question about Korg Pa800 Synthesizer
1. Error reading OS file ! 2. Error starting PL !
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Tip
Q: I have a collection of Anime, movie, etc. and then I have an iPhone. Most of...
Q: I have a collection of Anime, movie, etc. and then I have an iPhone. Most of the anime and movie are in Avi format, now I’m wondering if and how I can convert these avi videos to Mp4 for playback on my iPhone? (By the way, I have a pc running on Windows 7), Thanks!
A: If you have an iPhone, you may have encountered the same problem. You have bunch of movies which you have downloaded from internet, and you want to pull out your iPhone to watch a few clips when you’re bored on the road or if you have extra time between classes. While your iPhone only accepts videos in MP4 or MOV format, but most of your downloaded movies are in AVI format. And that is the question- how to put downloaded movies in AVI format to your iPhone so you can enjoy them on the go? Basically, it is not difficult to make it. What you have to do is to convert avi file to mp4 for playback on your iPhone.
Things You'll Need
An iPhone
Downloaded movies or videos in AVI format
AVI to MP4 Converter
A PC running on Windows OS (including Windows7 OS)
A PC running on Windows OS (including the latest Windows7)
For those windows users, there are various AVI to MP4 converters, both free and paid, such as free Handbreak, but for windows 7 users, like me, the only one I had a good luck is Wondershare DVD Converter Ultimate, which is handy for converting AVI to MP4 files and transferring these AVI files for iPhone. Now, let’s check out it together.
Steps to convert AVI to MP4 on windows 7 for your iPhone:
Step 1: Free download this Wondershare DVD Converter Ultimate, install and run it.
Step 2: Add AVI files
Loading AVI movies will be your first step. Click "Add Video" or just drag & drop your AVI files to the file list directly, you can easily add AVI files.
Step 3: Select MP4 as output format
Select iPhone video MP4 as output format from the categorized output formats list in "Profile" drop-down list and specify the output directory to save your converted files in "Output" drop-down list.
Step 4: Start to convert AVI to MP4 file
After you select MP4 format, hit the Start button to convert AVI to MP4 files. And all the tasks will be done at fast speed and high quality.
Step 5: Transfer MP4 files to iPhone
The last step is to transfer converted MP4 files to iPhone. Of course, you can use iTunes which is free but it only provides one way solution to transfer files from PC to iPhone. There is another option if you still want to get your iPhone files back to PC, you can use an iPhone Transfer, which can transfer files between iPhone and PC freely.
Tip:
If you want to edit your movies, such as splitting it into sveral clips, adding subtiltes, or adding watermarks etc, you can click "Edit" to make tailor-made movies as you like.
That's it, with easy steps you can convert AVI to MP4 for your iPhone. Enjoy watching movies anytime and anywhere.
on Jan 18, 2010 | Music
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
I want to use my sd card to put my own songs and when i change the song from an MP3 to MIDI file using the program WIDI 3.3 Pro. When i put the MIDI file which is the song, into the Sd card and then into...
You need to understand what the program is doing.
An MP3 file is a recorded music performance like a phonograph record. A MIDI file is a set of instructions for performing music, like sheet music. The converter program is an attempt to turn the record into sheet music. There is no perfect way to do that. You should have gotten something out of the program, though. It sounds more like a computer problem. Try a very simple sound file, convert it to MIDI, and see if you can get something out. If your keyboard can't read it, try putting any known good MIDI file on the card and read that. Possibly your keyboard will only read certain formats or sizes or speeds of cards. See if the manual tells you anything. It might read FAT16 regular speed cards under 1 GB, for instance, and balk at a SDHC 16 GB NTFS formatted card. So, do some detective work.
Apr 05, 2017 | Casio Lighted Keyboard LK90STADMC
My Boss br-8 keeps saying medium error. It's not reading any disc. It ask me to initialize disc that already have music on them.
If the disk had music that was not CREATED on the BR-8 you will get the error. The format is incompatible with computer formats.
If the files were created on the same BR-8, then you probably have a disk drive failure.
Try initializing a blank disk. If it will not, then you have a drive failure.
Also is it possible you are trying to read a 250Mb disk on a 100Mb drive? That won't work either.
Jul 25, 2010 | Boss Micro BR Digital Recorder
How to fix Toshiba laptop with missing or corrupt file WINDOWSSYSTEM32CONFIGSYSTEM
There are many ways to attempt a fix with this error you could try firsta boot into safe mode then running msconfig
select the diagnostic startup then reboot in the normal way this might enable you to find your error.
If this fails click the LAUNCH SYSTEM RESTORE which maybe able to use one of your restore points created at an earlier time (usually before an app install) this may give you the fix you require.
Dec 14, 2009 | Music
I have noise on ram samples
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
Sep 23, 2009 | Korg Pa800 Synthesizer
Roland. Bosss. Micro BR problems,
Remove card, reincert card and initialize again. card may also be fragmented, use card optimizer in menu.
Mar 07, 2009 | Boss Micro BR Digital Recorder
Korg Pa800 Synthesizer Logo
178 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
