Question about Mitsubishi ColorView XL30U Multimedia Projector
Input is out - Mitsubishi ColorView XL30U Multimedia Projector
  • 442 Answers
Sometimes the output is in, but the signal is not there.
try the other inputs with other signal sources and see if all are not working
Posted on Apr 11, 2011
What is the ohm value of the input volume controls on this amp?
For the Tascam DP-01 Digital 8-Track Portastudio, here are some of the specs:
  • Analog specifications
  • Inputs (A And B) 1/4" Phone (Unbalanced)
  • Input Impedance: > 10k Ohms (Max), Or 1 M Ohms (A Only) With Switch In
  • Guitar Position: 2.4 K Ohms
  • Nominal Input Level: -10 Dbv -
  • Maximum Input Level: +6 Dbv
    Effect Return 2 X 1/4" Phone (Unbalanced)
  • Input Impedance: 10 K Ohms
    Stereo Mix 2 X 1/4" Phone (Unbalanced)
Courtesy of Musicians Friend
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Mar 27, 2011 | Tascam Audio Players & Recorders
My Denon AVR1611 powers up and the TV sound works just fine, but after 5 seconds or so the sound quits and I have to press the quick select sat/cable button to start it up again.
hi,
There are two types of input for sat/cable in your amplifier. One is the Digital input and the other is the Analogue input. You didn't specified which one is currently used by you.
However, if you connect the digital input then you have to configure the input assignment to digital and for analogue input configure as analogue.
If you use analogue input and input assignment is in digital mode then the problem mentioned by you can occur.
First of all check the input assignment for sat cable. for that do the following
1. Press the menu button on the amplifier's remote.
2. Select input setup
3.select input assinment ( check the input assignment for sat/cable, If you are using the analogue
input select it as analogue,if your are using the digital input then select it as digital.
ok
Feb 17, 2011 | Denon AVR1611 5 Channels Receiver
How to program the autio vidio inputs for zenith tv
Hi cathie
If you have sound it means that the tv is in aux/video mode.
Now make sure that the video output of the vcr is connected to the same aux/video input that has the sound connected to. i.e input 1 or 2 .
Also you want to try and switch with another cable to make sure that the cable you are using now is o.k.
Another way to try the tv input would be to connect something else in that input(cable box ,dvd ,video game etc,)
Try it and let me know.
Feb 02, 2010 | Televison & Video
My harmony 550 always stops one input before the one I need on my TV. my tv has an input button that cycles thru all of the inputs. i've already checked that the inputs are listed properly on the setup...
On some TV's when you first press the input button it does not switch to the next input it just shows you the current input. It is the 2nd press that offten takes you to the next input in the list. This can cause problems with the Harmony. If your TV works this way then you will need to call Logitech and let them know about this issue. They can add the additional hit for you and then you can update your remote. If you are only using 2 inputs then A work around you can try is to tell the Harmony that there are more inputs, effectivly setting up Ghost inputs. You would put one ghost input after each input that you use. If there are 3 or more inputs then this trick will not work. The last work around is to remove unused inputs on your TV. Most TV will allow you to remove unused inputs. Then you can add one ghost input after each actual input: For example:
TV input1
Ghost1
DVD input2
Ghost2
VCR input 3
Ghost3
If I am missing some information just let me know.
I will do my best to help
Good Luck
Nov 30, 2009 | Logitech Harmony 550 Remote Control
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Humming
Do not connect your PC output to the Phono input, it is a mismatch. Thye output from the PC will be "line level" or the same level as tape input, aux input, CD input etc. The phono input line contains an extra stage of amplification required for turntables. If you attempt to use that input, you will fry it. Any of the other inputs on the receiver will work for you.
Dan
Apr 08, 2009 | Technics Audio Players & Recorders
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
51F510 Input settings for HDMI
Okey,
Connect the hdmi, into the HDMI 1. that is automatically input one. Connect the 2nd device on Input 2, thats next to input 1 and hdmi, leave the input 1 empty, as the hdmi is connected to that.
3rd device into input 3
4th device into input 4.
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Mitsubishi ColorView XL30U Multimedia Projector Logo
56 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
