Question about Maytag MAH6700AWW Neptune Front-Load Washer
Can I stack my Neptune Dryer MDG9700AW on top of my washer MAH8700AWW?? If so- is there a kit to buy?? Right now I have them on pedastals-
vest6
  • 196 Answers
SOURCE: Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Posted on Jan 15, 2008
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Posted on Jun 17, 2008
reg501
  • 413 Answers
SOURCE: my maytag neptune washer model
Look carefully in the inside front of the dispenser. You should see what looks like a red plastic string. (the type of string used on a power string trimmer) Pull on this string and the door should release.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Posted on Jun 22, 2008
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Want to know if I can stack a kenmore elit gas dryer on a kenmore elite washer and on top of a 10 inch pedistal or will it be too tall?
The appliances were not designed to be stacked so I would not attempt it if anything I would build a shelf (ledge) to put the dryer on, then bracket it to the wall but be careful of the height especially with a gas dryer and be sure to have plenty of space for airflow. Good luck
Mar 27, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
Oct 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Loud noise on spin cycle only clothes dry good
Sounds like your bearings and seal need replaced... See Neptune Bearing for information on the Maytag Neptune bearing and 12002022 seal kit. You can also rent a special tool kit that includes the bearings, 12002022 seal kit, bearing spacer, step by step DVD, etc.
I would not run neptune with bad bearings too prevent more damage to the Neptune spinner support, Motor drive system...
I hope this helps you...
Feb 01, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Stacking the washer and dryer
Been a while since I did one, but as I recall: Two side pieces secure to top of washer with peel off tape and a screw into the top at the very back of the washer's top. Dryer sets on top of washer with back legs sliding into the stack kit side parts. Front rail holds front dryer legs, secured by one screw on each side into stack kit side pieces after dryer is set on top of washer.
Nov 09, 2008 | LG WM-2277HW Front Load Washer
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Can I stack them easily? Do I need any accessories?
yes you need the stack kit. you can buy it a sears or any local appliance parts store. youll need to have to model number of the washer with you so youll get the right one
Nov 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
342 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
