Question about Pool & Spa
The pump wasn't pulling water into the skimmer to fill the skimmer all the way. We shut it off to change the filter, now the pump motor will not turn on, it just hums. Does the motor need replaced? It's a Pinnacle 35-5339 CX.
  • 31 Answers
With the breaker for the pump off, Remove the spindle cover at the back of the motor and make sure it spins freely. If it wont move then the pump will have to be taken apart to see what is obstructing it.
If it does spin, then replace the capacitor mounted on top of the motor itself. This can shock the bejeezes out of you so make sure the breaker to the motor has been off for several minutes and be careful! They cost about $20.
If this does not solve your problem than its time for a new motor!
Posted on Apr 18, 2011
How do i prime this swimming pool pump?
The normal procedure would be to unscrew the top of the inlet basket and fill that with water until it flow out down the inlet pipe, then replace the top cover. Make sure the skimmer box basket is clean, the pool water level is high, or put a fast running hose in the skimmer box to make sure the primed pump does not have to pull the water up from too low at the inlet.
If it will not pull the pool water in when started, then -
- there is a leak or blockage somewhere on the inlet side
- the pump impeller is damaged
- the filter is clogged too much and causing back pressure
- the pump power and pipe sizing are mismatched
Oct 08, 2014 | Pool & Spa
Intex pool pump runs for five minutes and then shuts down and service light comes on. What could be the problem as it was running fine the day before?
We don't have a service light on our pump, but usually when our is playing up it's because the pump is struggling to push enough water through - for example if the filter needs changing or if the skimmer isn't receiving enough water/water level is too low.
Nov 04, 2013 | Intex Automatic Salt Water System for ...
I shut off my pump yesterday and water shot out of the skimmer. when i turned the pump on it wouldn't work, the pump basket has water in it but it isn't pumping anything, no water coming out of...
I suspect you had air trapped in the filter. When the pump shut down, the compressed air in the filter pushed back, turned the pump backwards, and unscrewed the impeller off the motor shaft. This particular pump doesn't use an impeller screw which prevents this from happening. You will have to pull the pump apart to see if this is the cause. I have seen this happen many times.
Sep 15, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
My pump is running and water is returning to the pool but there is no suction.
Are you saying there is 'no suction' or there is 'little suction'? If your pump is running and water is going back to the pool, that water is coming from somewhere ... probably being pulled from the pool. Is this a new pool? If not, did it operate properly last year? Are you getting air into your system?
You don't say much about your pool ... is the suction line attrached to a skimmer? Two skimmers? Two skimmers and a bottom drain? Attached to the bottom drain? I don't understand why you are reporting no suction since there is a discharge ... Is this pool in the ground or above ground? Do you have one circulator pump or do you have multiple pumps? If you have two skimmers and are trying to vacuum, close the shutter on the other skimmer or put a plug into it. Make sure the plug is the proper size, you don't want to get the plug pulled into the system!
Perhaps there is not enough suction for you to vacuum? If your suction is attached to several points in your pool, can you cut back on the other ports? For example, if you are drawing from the bottom and a skimmer, can you shut the bottom drain off?
Have you checked your impeller for hair clogging? What about your filter, if sand, have you back washed? What is your discharge pressure? If DE, how is the DE doing? Might it be due for a change? If a cartridge filter, is your cartridge clean? Of course dirty filters will cause high pressure and poor flow of water. If your impeller is clogged with hair, that will impede the flow of water.
Fill in some of thedetails and I will continue to try to assist you. Thank you for your interest in FixYa.com
Jul 05, 2011 | Sta Rite Pool & Spa
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
I am contacting you as I am a bit desperate for help. Please advise as to what should be done with regard to the Savio Skimmer Filter SS0000. At around 5pm when feeding the fish, I noted the skimmer...
This means that the filter or leaf basket is blocked. When the pump is off, the water levels will look fine, but when the pump pulls water through, even a partial blockage of the filter or basket limits flow so the level falls and eventually the pump 'sucks air'. Remove and thoroughly clean the leaf basket and filter. Good luck!
Aug 12, 2010 | Garden
When I backwash or rinse my pump reservoir fills to the top when I filter I have air bubbles at pool discharge and reservoir about 3/4 full and air is evident. Do I need to start digging up my skimmer line...
When backwashing or rinsing the same water is used as in filtering.(skimmer and main drain) so I don't think skimmer damage is the issue. Check if the pool water is low at the skimmer after the backwash cycle, Also check to see if the skimmer weir gate (flapper) is stuck in the upright position. I would suggest 2 main checks. Fill the pool higher than usual, back wash, ensure the pool water level is 1/2 way up the skimmer level and try again. Also, if your lines are valved right, shut off the skimmer during the filter cycle and see what happens. Lastly, the gasket on your multi-port valve may be bad.
Jul 16, 2010 | Hayward 3/4hp Super Pump Inground Pool...
My Kreepy Krauly is working at half speed, any ideas? I've checked the tubing, no visible leaks, flapper works. Seems to pull air into the filter even after tubing is full of water. Both baskets clean.
Are you using a skimmer plate with the regulator valve or is connected direct to wall? Do you have a valve near pump that allows you to select skimmer or main drain or other input port? If so, select only skimmer. What is the pressure on your filter? Filter may need to be backwashed.
Aug 05, 2009 | Universal Kreepy Krauly In-Ground Pool...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
