Question about Dryers
Dryer stopped working without any previous problems. Interior light also does'nt work. I have checked 220 outlet and door switch with meter. It is a Crosley Model # CDE8000W. It was as if it was unpluged. Thanks for any help !
  • 413 Answers
Could be a burnt wire in the unit, check the connection where the cord goes in to the dryer. You may have to take a couple of screws out to do so. Also check for 220volts where the cord connects to the dryer. Be careful with high voltage.
Posted on Apr 11, 2011
The dryer stopped working while in use. There is now no power going into the machine. It is a Bosch Maxx 7 dryer.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
May 06, 2015 | Bosch Dryers
My Bloomberg DVDs 17540 dryer stopped in the middle of the cycle and now it does not turn on. I purchased this dryer 2 month ago and I barely used it as I like to dry most of my cloths in open air. But I...
Mar 16, 2015 | Dryers
THE DRYER WONT START,FILTER AND VENTS ARE CLEAR. HOW DO YOU FIX THIS PROBLEM?
Several reasons can cause a no start dryer condition. I'll start with the easy ones first. If a gas dryer, it runs off 120 volts. Check the house fuse or breaker or plug a light into the dryer outlet to make sure you have power. If outlet is OK then we have several dryer problems possible. If the dryer is electric, it run off 220 volts. You need a voltage tester to check the 220 house plug. Could still be a problem with the house 220 breaker. On the dryer itself, the first thing to check is the door switch. If the door switch is bad the dryer will think the door is open even when it is actually closed. Next, some dryers have a switch on the internal belt system. If the belt breaks, the dryer will not run.(only on some newer models). Couls also be a bad timer assembly. Some of these may need a tech to actually test since it requires taking the dryer apart to get to these item.
Feb 28, 2015 | Dryers
My tumble dryer is a candy grand O GOV580c and all the lights keep flasing and stops working??
Dec 21, 2014 | Candy Dryers
Dryer wont start.
Oct 30, 2014 | Dryers
Why has my tumble dryer stopped working when I know that power is getting into the machine?
Oct 02, 2014 | Dryers
I have as Kenmore 80 Series dryer. When we push start it does nothing
Sep 29, 2014 | Dryers
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
