Question about LG 42LG30 42 in. LCD HDTV
I have a LG 42lh30 that gets a distinct vertical bar, about six inches from the left hand edge of the screen. Occasionally the area between the vertical bar and the edge will be filled with small horizontal bars that flash. Sometimes after an hour or so, the bar and discoloration on that side goes away and sometimes it doesn't... sometimes turning the tv and jiggling the wires on the Aux. AV port will make the line go away, sometimes it doesn't. Is it fixable?
    Top Expert:
  • LG Master
  • 74,251 Answers
Hello
The fault is due to its horizontal sync-seperator and horizontal phase detector section, and it is not user servicable. If you want to do it by yoursef, you must have thorugh knoledge in both digital and analogue electroncis, and a high quality digital multimeter to access these sections. A multimeter of the above said type will cost a lot, that it will be a great loos for you to muy such one, more that its service cost. Moreover, you must have a good concept of solering, a sodering iron with ceramic tip, a very steady and stable hand, more patience and concentration, A magnifying glass may also needed.
In my opinion, it will be best for you to get it repaired by a well experienced service technican, who have most modern testing equipments. Otherwise, things will go worse than present as it is. OK.
Posted on Apr 11, 2011
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
LG 42LH30. About six inches of screen on left side goes white. If pinch outer edges make it go away but seems to come right back.? Suggestions. ?
This is most likely the panel itself, but could possibly be the wiring. Check the wiring on the panel to be sure it is not corroded, loose or broken. if it is any of the fore mentioned repair or replace the cable.
If it is the panel & under warranty, contact Manufacturer. if it is panel & out of warranty, replace unit as panel replacement is not cost effective even if the panel is available.
May 15, 2015 | LG Televison & Video
On a 58" diagonal plasma, I have an approximate 3-1/4" wide pink vertical bar in the lower left corner of the screen. It does not go all the way to the top of the plasma, it stops mid-way on the scre
There is some connection defects. If you wish to know more about these kind of fault to plasma displays, check this link. There is illustrations to compare with, which cannot be included by this window.
Feb 25, 2013 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
42lh30 has bright spot in centerof screen, it's only visible on shots of black screen, but it is whitish and about 8 inches in diameter
This problem is cased by the LCD panel.You have to sent for repair the panel itself.In my knoledge it is only you can do through the suppier of the TV
Sep 28, 2009 | LG 42LH30 42 in. LCD TV
Red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Sep 18, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
42 inch LG plasma
Check the COF panels if there are SMD resistors on it,resoldering the resisters could fix the problem.
Aug 05, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Taskbar is hidden by about an inch of coloured vertical lines!
Left click on the top edge of the Task bar and hold it doen, and drag it down to resize the task bar to the size you want then release the left botton.
Apr 05, 2009 | Compaq Computers & Internet
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG 42LG30 42 in. LCD HDTV Logo
117 people viewed this question
Computer Repairing
Computer Repairing
