Question about Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
Whirlpool Duet Gas Dryer, Model ggw9200lw0. The dryer won't heat up. The thermal fuse and igniter has been replaced and the lint has all been cleaned out. Still not action, the igniter does not glow at all. Doesn't seem like anything is happening near the burner assembly at all.
Posted on Jun 12, 2011
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Posted on Apr 10, 2011
  • dssinstalls Apr 11, 2011
    thanks.... thats what it is on mine too
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Duet gas gas dryer has no heat
does the flame go on and then shut down if so make sure vent hose is clear all the way through if ok then you need to locate the blower wheel and make sure there isnt a sock jambed in it and its tight on the shaft not spinning loose they crack and are servicable.
Aug 28, 2012 | Whirlpool GGW9200L Gas Dryer
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
New Whirlpool Duet gas dryer (wgd9300vu) won't heat.
if its brand new,
anmd its gas, well then more than likely it was dropped, when it was dropped the graphite ignitor craked or broke due to shock impact,
i delivered units for 5 years and saw this numerous times.
I would tell you to fix it your self, but its brand new, if the company you bought it from has service they should give you a free service call and part
Oct 21, 2009 | Dryers
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Mar 16, 2008 | Dryers
Dryers Logo
621 people viewed this question
Top Dryers Experts
