Question about Canon Office Equipment & Supplies
I have a mf8050 color laser printer. I have had nothing but problems with this thing. I have had someone come to the house and work on it 2 times. When one problem solved another pops up. On that problem we finally just quite trying to connect through airport for a network in the house. Well anyway - today The printer will not print the text from a document from the computer. It does print the colorful icons within the text. It copys a document text straight from the printer though. I have turned it off and waited and on. Still it will not print the text just a blank page. Any suggestions?
    President:
  • 2,047 Answers
Usually laser printers rarely give such problems as you have described because they dont use cartridges like deskjet printers. The previous problem of connection has to do with proper networking and unless it is examined in person precise and concise tips cannot be given.
To print the document from the computer try changing the color of the text on the PC to a different color preferably a bright one and attempt to print. Usually this should work. If it prints this means that the toner is getting bad and needs replacement as some of the inks which aid the printer to mix the exact color is not available.
Hope this solution has been helpful?
Posted on Apr 10, 2011
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Apr 17, 2015 | Ricoh Aficio SP C420DN Laser Printer
My printer print with black i can't make it print colored documents
You should try the cleaning process several times. If that doesn't work then try changing the color cartrage?
Aug 10, 2014 | Canon i-SENSYS MF4730 Multifunction Laser...
Service mode canon mf8050
hola, por favor si pueden ayudarme, tengo una canon mf-8050 cn y emite error E202-0001.gracias
Apr 11, 2013 | Canon MF8050Cn AllInOne Laser Printer
Error code on canon mf8050 code is: E198-0000 how can I fix this?
Error Code on Canon mf8050cn Code is E198-0000 How can I fix this?
Oct 28, 2010 | Canon LASER SHOT LBP-5000 Printer
Thinking of buying a used HP 2840 but just heard bad news . .
HP LaserJet 2840 is an old machine. I would like to propose Canon imageCLASS MF8050 to suit your requirement.
May 26, 2010 | HP LaserJet 2840 All-In-One Printer
Prints gibberish when a multi-page color document is printed
This could be a driver issue. Without knowing exactly how your printer is connected to the network I'm making a rough guess here.
There is a Universal HP Printer driver that could be tried as well as the PCL5, PCL6 and Post Script drivers.
I've had issues with the PCL6 drivers before doing this and I usually install the PCL5 drivers instead.
Jun 21, 2009 | HP 4700N Color Q7492AABA Laser Printer
Canon ImageRunner 3200
there are several steps before reaching the laser i-- clear dc con then take machine off remove plug from outlet then power up machine 2--clean the itb assembly thoroughly 3---change the transfer belt 4 --- change the itb assy. if nothing works then we will go to the laser
Jan 06, 2009 | Canon imageRUNNER C3200 Copier
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
109 people viewed this question
old marine
old marine
