Question about RIM BlackBerry Curve 8530 Battery
My battery overheats, it is swelling and it shuts off frequently. any suggestions?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 17 Answers
You overcharged it. If you have the budget, buy a new battery because it may cause short circuits. :)
Posted on Aug 04, 2013
Engine would not start and now the battery is swollen
Hi check polarity of battery ,2 look at the wiring loom look for cable damage shorting burning ,3 I think its more than likely this , you need to ask why when you hit the kill switch did it not shut off ,4 check the rectifier , also ask did you get anything done fitted eg alarm lights ,to swell the batt then it had to get an unusually high charge in reverse please let me know how you got on
May 25, 2014 | 2006 Hyosung SF 50
Battert tab broke when attempting to remove (replace) batteries. Cannot get old batteries out of Smart UPS1000. Front-most battery appears to have swelled.
You'll need to remove the cover and battery cage from the unit. I've run into this before, just take your time and be careful there are likely some sharp edges inside.
When the batteries overheat and swell, they press against the metal in the unit and get wedged in.
I found a related post about APC 3000s.
Dec 09, 2012 | APC Smart-UPS 1000VA UPS System
Intermittently powers off both with battery and without on mains
First thing you have to do is heat management. for that, place the laptop base in an even surface and never on a bed or cloth as this will stop the air intake throgh the bottom fan and cause it to stop or restart frequently when heat exceeds. secondly the fan vent may be blocked with accumulated dust thus the hot air is spreading in and leads the system to overheat and shutdown or restart frequently. A motherboard failure also shows this symptom. Consult a laptop technician incase you recognize the 2nd and 3rd problem.Hope this helps
Dec 29, 2011 | Samsung R Series Laptop NP-RF510-S02US
Razor e300 batteries are bulging. Is that normal?
Bulging battery means u have to replace it, the plates started to oxidize and pushes the everything out!
Nov 09, 2010 | Razor E300 Scooter
I have a deq-9200 one day it just shut off, I've tried everything, fuses , etc.i dismounted the central part (not the display) and noticed there was a liquid that leaked. Any suggestions?
Check the capacitors near the leak source if they vent ie swell on top then it is possible they have split causing fluid leakage they will not be far from leak on pcb replace the ones that look swelled
Jan 06, 2010 | Pioneer DEQ-9200 3-Band Car Equalizer
My cousin Changed the thermostat on his 02 grand cherokee and failed to open the bleader screws to bleed out the air the hose swelled up larger than normal and was rock hard. A line that come from the...
I think your the one to work on your cousins veh. I agree so for with what your said except the swelling hose part. Go back and pull the thermostat. Wrong one or went in wrong.
Sep 25, 2009 | 2002 Jeep Grand Cherokee
The low battery light appears frequently. Some
check that battery cable clamps & posts are clean & tight
Sep 21, 2009 | 2001 Oldsmobile Intrigue
Fan slows down and also stops suddenly on its own
motor windings are going bad. The winding swell as electricity goes through them putting pressure on the shaft. The reason it shuts down is for safety so it won't overheat and start a fire. Recommend replacement. Hope this helped Good luck
Dave
Sep 16, 2009 | Lakewood 16" Stand Fan
Computer is turning off frequently,automaticaly.
IF it is windows it is something to do with power management go to control panel and in power management disable the restart option and diable the hibernation mode too and in BIOS reset to default
Jul 02, 2009 | Computers & Internet
RIM BlackBerry Curve 8530 Battery Logo
129 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
