Question about Toshiba Satellite A205-S4617 Notebook
When u hit button to turn computer on it does nothing. It shows the green lights and is hooked up to power but the battery will not hold charge. If battery is shot will computer not turn on even when hooked to power
  • lindseyconst Apr 10, 2011
    The fan runs when u push start button and the bottom
    is hot?
  • 52 Answers
Hello, Most Laptops will still turn on as long as there connection through the battery to the computer. I have had a few laptops with 100% dead batteries that still work. Can you hear the fans inside spinning? Does the bottom heat up? We are trying to determine if the problem lies within the hardware or software. That should put you a few steps closer to fixing the problems!
Best Wishes and Good Luck!
Posted on Apr 10, 2011
  • Derek McClellan Apr 10, 2011
    Since the fans turn on and the bottom heats up I would assume that the power supply, fans, and processor are still good, What Do you see on the screen? Is it black screen or blue screen? Anything flicker? Black screen could mean, other hardware issue, possible broken screen connection, blue screen could mean, dead hard-drive, Os failure, among a few other things. Hope this helps!
Bluetooth fail so we copy it.
  • Espinas_30 Apr 10, 2011
    it s Problem about bluetooth for copy need it. and address : orchid valley subd ph 3 mahabang parang angono Rizal, philippines this name is kim m. espinas
What's your question? my proline laptop is not showing up the screen but it does show that its charging but doesn't show up the screen
That could be many problems. what your telling me is that u see the charge light when u charge it but when you turn it on nothing happens? this could be a number of things. I would hook up a monitor and see if anything shows up on the monitor if the laptop boots. if something does show up then its your laptop display cables that are bad.
Try This
--> First turn your computer off by pressing and holding down the start button. Next unplug the computer and then remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. No results usually indicates a bad mother board. Hope this helps.
Mar 05, 2016 | Computers & Internet
My computer says it is charging but as soon as i hit the power button it stops charging and does nothing even happens
Have you tried running the computer with just the AC plugged in and not with the battery? If not try that. It could be the battery is going out. I had a similar issue once. If that doesn't work it might be the power supply / powercord or it could be the motherboard.
Jan 17, 2013 | IBM ThinkPad T30 2366 Notebook
My HP Pavilion dv9740us Notebook PC dosent start the screen is black
Doesn't start as in nothing happens when you hit the power button? Or are you saying the Desktop is black, but it seems like windows started and went through the boot process?
If nothing happens when you hit the power button:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 20, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
I hit the power button and it turns green for a second but then goes out. The camera and LCD screen do nothing. So I have some sort of power problem. When I put the battery in the charger the charger light...
theres no choice your battery charger is may be out and try new battery and try the power cable from the charger and connect directly to the cam if you got the original power pack/ for the green screen it can go green or bleu when the battery go low, some time that is the video processor ic...
i hope for you it just the battery....
and good luck
May 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Green charge light on, power button will not switch it on
even though the green light is on, hook it up to the usb cable2_bing.gif to your computer for a few hours,(make sure the green power light on the front is on) then press and hold the power button for up to 15 seconds.
if that fails, let me know and we can try something else
bill
ALL That is necessary for the Triumph Of evil is That good men do nothing.
Dec 09, 2009 | Tomtom ONE GPS Receiver
Camera problem
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Feb 10, 2008 | Pentax Optio M20 Digital Camera
Hold menu down 20 sec. will not come on,hook up pc show full battery.sanase250
Try unplugging it from the computer hold down the small power button until any light on it turns off.
Move the button on the top from right to left
Turn on.
Dec 06, 2007 | SanDisk Sansa e250 MP3 Player
Toshiba Satellite A205-S4617 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
