Question about Bushnell NorthStar 78-7880 (190 x 78.74mm) Telescope
I just purchased a northstar, goto telescope, model 78-8876. I purchased it second hand. When I try to turn on the power on, I have to keep the power button pressed down to have power, I let go, the power go's out. But even while I have the button pressed, I can't get the telescope to respond, or move. The remote will be lit up, and I can go through the set up, but its as if the telescope itself doesn't get power. Keeping in mind, I'm doing this with the power button manually pressed in all the time. I do have a new energizer battery in the unit..... Any suggestions? Thanks.....
  • 3,186 Answers
Obviously either your hand controller is broken and or a circuit inside the scope.
Here is Bushnell's repair web site:
http://www.opticsplanet.net/bushnell-warranty.html
Posted on Apr 11, 2011
Hello, I have Bushnell Northstar 78-8831 telescope which I got from United States (New York) last year. Since the very first day, I am not able to get the option of "Align Start 1" After...
This can be caused by many things-- such as dirt or grease on the encoders inside or a slipping clutch. I know you just bought this telescope, but Bushnell is NOT KNOWN for having quality telescopes.
To get the goto to work everything must be according to the manual.
The tripod needs to be perfectly level-- time, date, and site must be accurate, and the alignment objects must each be centered in the eyepiece. Sounds like you also have electronic issues with the hand controller. Only Bushnell can repair this scope.
Apr 04, 2011 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Viewing
take it back where you got it for replacement
Nov 19, 2007 | Bushnell NorthStar Goto 100mm 788840...
We purchased a 78-5880 North Star for our son for Christmas. I have skimmed the manual, but the family wants to dive in and begin using. They are wanting to take it back because they have been unable to...
All of Bushnells manuals are on this web site:
Usually there is a setting in the hand controller to adjust brightness. Make sure the batteries are FRESH and new. Put the eyepiece with the largest number written on it into the diagonal. DO NOT use the 2x barlow if you have one.
Read my tips on GOTO scopes on my profile page.
Jan 06, 2011 | Bushnell NorthStar Goto 127mm 788850...
Need to clear bushnell northstars menory
Bushnell has never given instructions on how to do this. Try calling their service center here:
Sep 05, 2010 | Bushnell NorthStar Goto 100mm 788840...
I have a bushnell northstar 78-8831 and need to know how to reset the telescope. when in align earth mode it asks me to align star 2, skipping over star 1.
This scope has many goto issues. For one there is no way to reset the controller or to reload the firmware inside the hand controller. The firmware is probably corrupted.
You can contact their repair and support web site here:
Aug 10, 2010 | Bushnell NorthStar 78-8831 (525 x 76mm)...
How come when I look at a planet or star throught the super 4 eye piece, it is hard to get the focus sharp enough to even see the object clearly. Especially when Im turning the focus knob which moves the...
Hand controllers do NOT like cold weather. It's just a function of the LED lights. Put the hand controller in your pocket to keep it warmer than the outside temperature.
Your scope has a maximum magnification of about 40 times aperture. So about 200 power. If you exceed this the image just starts to degrade -- it gets bigger BUT fuzzier.
Stay with lower magnification eyepieces. Certainly above about 10-12mm...... You will get better views using eyepieces from 15-22mm, and you need one wide field low magnification eyepiece of about 30-32mm.
Dec 29, 2009 | Bushnell NorthStar Goto 100mm 788840...
The hand held unit lights up when turned on, and the telescope "homes" but the LED does not show anything. The voice speaks "Bushnell Northstar" but very quietly. The telescope can be moved by the bottom 4...
Can you reverse the cable end to the hand controller-- a bad cable can cause this. Also low power supply, depleted batteries can also cause this.
Return the hand controller for replacement if batteries and or a new cable do not fix this.
Dec 24, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Bushnell Northstar GOTO 78-8850 On/Off Button
I have read the manual and they're not clear on this. The base of the telescope is what sits on the tripod. It is where you store the controller. You should find the power switch near where the controller gets stored.
I hope this helps.
-jodair
Mar 26, 2009 | Bushnell Northstar 78-8850 Telescope
Can't view anything.
point it at sunset the oppisite way from the sun
Dec 27, 2008 | Bushnell NorthStar 675x4.5'' GoTo...
Bushnell NorthStar 78-7880 (190 x 78.74mm) Telescope Logo
313 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
