Question about GE Washing Machines
Replaced the lower transmission seal on my washer and I need to know what kind of oil to put back in it
    President:
  • 2,187 Answers
There is a specialist oil for washing machines. IT is called gear case oil. You may check your dealer or manufacturer for details.
Posted on Apr 10, 2011
Testimonial: "Thanks guys "
Oil stains inside of washer on the aggitator.
The transmission seal has gone bad. That typically happens when the bearing wears and becomes "sloppy", putting pressure on the seal. If you're getting oil OUT of the transmission, you could be getting water IN, which is pushing the oil out or the oil could be coming out just because of heat. Either way, you'll need a transmission.
Mar 19, 2011 | Kenmore 24032\24036 Top Load Washer
Tip
Troubleshooting oil leaks on Nissan Altima
    Your Altima uses a variety of different oils to lubricate various components. Normally, these oils won't leak. But when you do find a leak, you will almost always need to have extensive work done on your Altima to correct the problem. However, before you can replace anything, you need to know what kind of oil it is
    Check for brown or black oil leaking on the ground or on the side of the engine. This is engine oil. It lubricates critical engine components. A leak means that an engine seal has failed and needs to be replaced
    Check for red oil. Red oil is trans fluid. On your Altima, it most likely means that you have a rear main seal on the transmission that has failed. However, any seal on the transmission is possible. Transmission leaks need to be fixed immediately. A transmission can fail catastrophically in 20 minutes of driving if there is insufficient oil in the transmission
    Check for amber or brown oil leaking from your trans. This is transmission gear oil found only on the manual version of the Nissan Altima.
on Mar 03, 2011 | Nissan Altima Cars & Trucks
I am finding oil under my washer.
your transmissions lower oil seal is leaking and needs to be replaced,if the top seal goes,you will start to see oil droplets on your clothes when washed and this is called "wash-back"
Jan 01, 2011 | GE WBSR3140DW Top Load Washer
Lower unit oil
On the lower side of the gearbox,below the line of the prop shaft,you will see a screw that is about10-15mm across.This is the drain for the g/box oil.If you look above that screw about 150mm(6 inches),you will see another screw the same.It may even be marked 'oil level'.Remove them both.
Checked the drained oil is not milky.It's a sign of water and the propshaft seal would need to be replaced.
The oil bottle you buy will have a tapered nozzle.You must fill the g/box from the LOWER hole by sqeezing the bottle.When it comes out of the UPPER hole,the g/box is filled.Quickly put the lower screw back in first,and then the upper screw.Done.
Before you refill the g/box,check the washer/seal on the screws and make sure they are still good. Hope this helps
Jul 09, 2010 | Boating
Kenmore heavy duty washer leak oil out while putting belt on where do I put oil in at and what kind of oil
It sounds like your tansmission seal is leaking. I don't know of any washer you put oil in.
Jan 06, 2010 | Kenmore 23822 Top Load Washer
Were are the oil drain bolts on the 2003 honda 450
The engine oil drain is on the lower left side of the crankcase, beneath the crankcase side cover toward the front. Bolt w/copper or aluminum sealing washer. Transmission drain plug is on the lower left side also but to the rear just back of the cover. This is a larger bolt w/sealing washer. These things are tricky to find the first time because they are not located in the usual bottom locations.
Dec 04, 2009 | 2003 Honda CRF 450 R
My amana washer is putting oil on my clothes. what is the problem?
your top transmission seal is leaking oil out of tranny, it's called "Back-Wash" you'll need to replace the seal,seals cheap, labor expensive,rebuilt tranny $150-$250 if this is the problem and machine is old trade it
Aug 29, 2009 | Amana Washing Machines
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
Transmission refill capacity
Contact support staff at www.searsdirect.com they may be able to help.
Jul 11, 2017 | Amana 3.2 cu. ft. Top-Load Washer
Leaks lime looking oil
The problem is the bottom transmission seal. This can be fixed with a few basic tools without calling a tech. Lay the washer on it's back, block up the tranny support and remove the pulley and seal. you might want to consider changing the belt and lower transmission bearing also. Total price of these parts should be around $50. Don't worry about the loose of oil.
Dec 22, 2007 | Washing Machines
Washing Machines Logo
123 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
