Question about Dryers
Dryer stopped running in the middle of the cycle and now won't start again
    Brigadier General:
  • 3,301 Answers
You may have overloaded the heat circuits. since you haven't provided the model or brand I can only give you a normal solution to this type of problem, each dryer has a main fuse located under the backing cover, if the dryer is doing nothing at all, this fuse is the problem. If you know how to use a multimeter, unplug the unit, place the test leads on either side of the fuse with the setting on continuity , no reading is bad fuse, The good part is they are easy to get and reinstall yourself
Posted on Apr 11, 2011
Kenmore 600 series dryer won't start. Interior light comes on
Strong possibility your dryer fuse has melted due to a lint buildup in the filter chute of your dryer. Check out my photos of a dryer tuneup I did last summer. ROPER DRYER TUNE UP
SERVICE MANUAL AND MORE PHOTOS
Jun 16, 2012 | Dryers
We have an old Frigidaire dryer (1993). It stopped in the middle of a drying and won't start again. The light goes on, the buzzer goes off when tested, but it won't start turning. It is too...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
The dryer stopped in the middle of the cycle and now it won't come on at all when I push the start button
heatman101
Jul 20, 2011 | Kenmore Dryers
Dryer stopped in middle of cycle and won't start now. Looking at all the fuses and switches and they work fine. I'm thinking it's the drive motor. Can that be the problem and it there anyway to...
heatman101
May 15, 2011 | Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
Top Dryers Experts
