Question about West Bend 82306 Stir Crazy® Popcorn Maker
Stirring rod stopped
Bought a new westbend stircrazy for Christmas 07, our third in 28 years....and 8 months later, the stirring rod stopped working....is this a big problem or can we fix it?
  • 2 more comments
  • mailaminute Aug 30, 2008
    I was wondering if the motors were available or if it'sjust best to start over. Thanks for the try
    These weren't available locally at Christmas so I paid $45....sad huh? But probably you are right, just best to get a new one. In the meantime, microwave popcorn is standing in for the good stuff.
  • mailaminute Aug 31, 2008
    Using good popcorn and Corn oil is the secret for making the good stuff in a stir crazy, doesn't need anything but salt. My family was raised on vats of popcorn for every occasion.
    Orvilles light kettle is my favorite microwave flavor. Yum
  • Anonymous Feb 19, 2009
    Same problem with rod. Motor like froze. Maybe oil is conjealing down in the gears. New motor? Shame to toss the whole unit. Not that old, either or heavily used.
  • 13,433 Answers
Hey,
The stirring rod is operated by a motor on the bottom of the popcorn maker, if the rod is not moving, it means the motor is not moviing either. Most likely faulty motor, and it should be replaceable by opening the bottom of the maker. If the motor rotates but the rod doesn't move, something is cut in between the motor and the rod.
Thanks,
Ekse
Posted on Aug 30, 2008
  • 1 more comment
  • Ekse Aug 30, 2008
    Not sure, would need to know what it says on the motor to see if I can find a replacement. but here are some parts
    http://www.abtecparts.com/westbend_popco...
  • Ekse Aug 30, 2008
    The whole thing costs around 30$ - Not sure if its worth the new motor and takeing the maker apart to replace the motor.
  • Ekse Aug 31, 2008
    Hmm, How do you make your popcorn? If your popcorn is tasteing better than mine id sure like to know how you make it. :-)
    Thanks
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
Need replacement wire rod show phto
Replacement parts for your West Bend 82306 Stir Crazy® Popcorn Maker may be ordered on-line from this site:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=3906&secid=87&linkon=subcategory&linkid=108
Feb 28, 2011 | West Bend 82306 Stir Crazy® Popcorn...
What size is the popper 6 or 8 qts
The West Bend 82306 Stir Crazy® Popcorn Maker ca be either 6 or 8 qts.
The 6-qt model has a rounded domed shape as per the picture above; the 8-qt model has a straight-sided top.
The User Manual can be found here:
http://www.westbend.com/supportdata/L5557B_StirCrazyPopper_ALL.pdf
Jan 31, 2011 | West Bend 82306 Stir Crazy® Popcorn...
Nikon D90 update
Depends on the urgency of your needs. A quick look at the timeline (very bottom of the wikipedia page - need to click "show" on timeline)
http://en.wikipedia.org/wiki/Nikon_D90
Would indicate that its almost come to the end of its two year lifespan, but it wasn't mentioned in the "leaked" (maybe!) document about the big plans for 2009/10.
http://www.wired.com/gadgetlab/2009/07/entire-nikon-2009-2010-dslr-product-roadmap-leaked/
However, I'd expect them to be doing something in August / September (for the Christmas market) as its the flagship of their mid range.
They only typically announce a month before it goes on general releae, and as none of the photo mags seem to be currently covering "even rumours" - I'd guess at later this year.
So, if you can wait six months......
Hope this is helpful
(Sorry to hear about your loss).
Mar 02, 2010 | Nikon D90 Digital Camera with 18-105mm...
My blower only works on setting 123 + air con not that cold
You have a resistor array assembly going out. What you described is typical of the first resistor going out and over loading the second, which goes out and overloads the third. Replace the HVAC resistor array. Don't buy a used one. Spend the extra money on the new OEM dealer item. Good luck to you.
Apr 20, 2009 | 2000 Jeep Cherokee
Lost part for rocket fishing rod
The same thing happened to my kids rods.
A friend suggested a product called Bobber Stopper.
It's basically a small bead and string. I found that the bead would not
reel back in, but if you just tie a piece of sting on the line big enough
so it does not fit through the bobber. It worked for me, so hopefully
this will work for you.
Mar 16, 2009 | Rocket Fishing Rod
West Bend 82306 Stir Crazy® Popcorn Maker Logo
329 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
