Question about HP Computers & Internet
My hp 650 laptop won't turn on. I have tried taking the battery out and unplugging it
    Sergeant:
    Champion:
  • 207 Answers
Your board problably burned out needs testing..
Posted on Apr 10, 2011
Power turned off but on charger over night won,t turn back on
Take out the battery, disconnect the charger, leave everything off and unplugged for 5 minutes. put it all back together and try turn it on again. If this does not work, there could be something deeper that is wrong. Might need to take it to a service center
Jul 13, 2014 | ASUS Computers & Internet
My HP Pavilion dv6830US Notebook overheated and now won't turn back on. What can I do?
I would start by cleaning the fan, vents and heatsink. Use a can of compressed air. You may have to open the Laptop to clean thoroughly with the air and a light brush, use ESD protection as well. . Improve air flow from the bottom of the laptop and the side vents, a Laptop Cooler is a option. Hopefully you haven't done damage to vital components due to overheating. Unplug, remove battery, leave battery out, plug in, try to reboot.
May 26, 2013 | Computers & Internet
Laptop won't startup on power or battery
Step 1:
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 07, 2013 | ASUS F3SV-B2 Notebook
Hp pavilion laptop won't come out of standby
See if this works for you.
Unplug the power, remove the battery. Wait 2-3 minutes. Plug the power in without the batter. Turn on the system.
I do this for fun & feedback not $$$
Jim
Oct 03, 2011 | HP Pavilion dv1000 Notebook
MY COMPUTER WON"T TURN ON YET INDICATOR LIGHT WHERE CHARGER GOES INTO IT SHOWS LIGHT> Plugged in but will not powerup screen black. THIS IS A G60 HP Laptop
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 16, 2010 | HP G60-235DX Notebook
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
HP Laptop
unplug the adapter from laptop, then take battery out adn wait 5 to 10 secs, then reinsert battery and try turn it ON
if that doesn't work, take battery out and try power ON with adapter only.
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
377 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
