Question about Bling Software Podmaxx 09 for PC
I updated my Podmaxx09 software and it does not recognize my iPod Touch G3
Screen shows usb and Itunes but computer doesnt recognize ipod.
1. Verify if your pc passes the system requirements.
(a) usb 2.0 port
(b) You are running the latest version of itunes
2. Recharge your iPod Touch
3. Check USB connections. Use a USB port that is built into the computer instead of using an external usb hub.
4. Restart iPod Touch. Do the following steps: To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
5. Restart your computer then reconnect your iPod Touch
6. Try reinstalling iTunes. And if this doesn't resolve the issue, you can also try uninstalling iTunes then reinstalling the latest version.
7. Check if there are third-party software that might prevent iTunes from recognizing your iPod touch. Such software may be security software, anti-virus software and webcam drivers. What you can do is adjust the software settings or you may also temporarily disable the software.
If you find this helpful, kindly click the thumbs up button. Thanks! :)
May 23, 2011 | Apple iPod touch
Tip
How do I Update my iPod Touch With a PC
<p>It is essential to your iPod Touch up-to-date for proper operation. Updates the device with the latest software updates and bug fixes. Using Apple's iTunes application to update the iPod Touch via a PC. The iTunes software is also updated to ensure that the iPod is correctly updated. Updates both programs are a simple task and will help you get the most out of your Apple products. <br /> <p><br /> <p>ITunes update <br /> <p>1. Open iTunes on your computer and click on "Help" menu at the top of the application window. Click "Check for Updates". ITunes checks for available updates. <br /> <p><br /> <p>2. Click "OK" and "This version of iTunes is the current version" dialog box appears on screen. <br /> <p><br /> <p>3. Click "Download" dialog box "Update" when it appears on your screen. Follow the onscreen instructions to complete the update of iTunes. <br /> <p><br /> <p>IPod Touch Software <br /> <p>1. Connect the iPod Touch to your PC using the cable for iPod. <br /> <p><br /> <p>2. Wait for iTunes recognizes the iPod Touch. The "Download and Installation" dialog box appears when an update is available for the device. <br /> <p><br /> <p>3. Follow the instructions on the screen by the installation wizard to update the iPod Touch to apply. The update is complete when "OK to Disconnect" appears on the top of the iTunes application window. <br />
on Aug 05, 2011 | Apple iPod touch
Tip
How can I get a software update iPod touch?
<p>Apple develops and markets new software update for iPod touch control software on a regular basis. These upgrades range from technical solutions for seamless upgrades major program of entirely new possibilities. Like most aspects of Apple products, the update of the iPod Touch is almost automated. Connect the device to your computer and access to the "Check for Update" iPod Touch function to determine if a system upgrades are available. If an update, iTunes will automatically install for you. <br /> <p><br /> <p>1. Connect iPod Touch to your computer using the USB device. <br /> <p><br /> <p>2. Open iTunes on your computer. <br /> <p><br /> <p>3. Click on your name iPod Touch "devices" in the middle of the left column in iTunes. <br /> <p><br /> <p>4. Click on the "Summary" tab. <br /> <p><br /> <p>5. Click the "Check for Update" button in the center pane. ITunes checks for updates. <br /> <p><br /> <p>6. Click the "Update" when prompted to install the new software version. ITunes takes a few minutes to update your iPod Touch software. If you already have the latest update, a message that your iPod Touch is updated. <br />
on Aug 05, 2011 | Computers & Internet
I forgot the password to my ipod touch
There is only one way, you must restore the ipod which wipes out everything if you forgot it.
Updating and Restoring iPod touch Software
You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch.
• If you update, the iPod touch software is updated. Your downloaded applications, settings, and data aren’t affected.
Note: In some cases, an update may also include restoring iPod touch.
• If you restore, the latest version of iPod touch software is reinstalled, settings are restored to their defaults, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. If you’ve backed up iPod touch with iTunes on your computer, you can restore data from the backup at the end of the restore process.
Deleted data is no longer accessible via the iPod touch user interface, but isn’t erased from your iPod touch. For information about erasing all content and settings, see “Resetting iPod touch” on page 122.
Update or restore iPod touch:
1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2 Connect iPod touch to your computer.
3 Select iPod touch in the iTunes sidebar and click the Summary tab.
4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available.
5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
For more information about updating and restoring iPod touch software, go
Feb 06, 2010 | Apple iPod touch
New itouch, downloaded apps will only open for a second. help!
Before I begin, I must state that my expertise is limited because of the small amount of details you have provided. I will post my best solution now, but please show more detail in the future.
I am assuming if the iPod touch is new, it is a 3G (third generation, not to be confused with the 3G data network). Either way, my solution would be about the same for the 1G, 2G, or 3G. I own a 2G right now.
The "only open for a second" problem is called "crashing". The fact that it is crashing could mean that you need the most security, available in Apple's latest software updates. Please try to download the latest update by reading the below instructions:
If you haven't already, please download and install the latest version of iTunes from www.apple.com/itunes . Then, plug your iPod into the computer via the USB cord that came with the iPod. After iTunes and your computer both recognize it, click on your iPod in iTunes. Then click Check for Software Update to download and install the latest iPod touch software directly from Apple for the most security.
Cheers and good luck,
DMKlunk
Jan 01, 2010 | Apple iPod touch
Tip
MediaMonkey Learn how to recognize an iPod Touch
<p>As one of the desktop media players available today as an alternative to iTunes, MediaMonkey lets you transfer music, videos and other content to manage their iPod devices including the iPod Touch. However, MediaMonkey does not come installed with all drivers and other software components needed to recognize the iPod Touch. Therefore, you need the latest version of iTunes installed on your computer if you use your iPod Touch with MediaMonkey. <br /> <p><br /> <p>1. Download and install the latest version of iTunes on your computer. The software, available free from Apple's site contains the software components needed for a program on your computer, including MediaMonkey, to recognize the iPod Touch. You do not have to keep iTunes open while using the iPod Touch with MediaMonkey, but you should have downloaded and installed the program. <br /> <p><br /> <p>2. Connect the iPod Touch to your computer using the USB cable machine white. Close iTunes, since that opens up when you do this. <br /> <p><br /> <p>3. Release of MediaMonkey. Scroll down the browser on the left and note that the iPod Touch now appears in My Computer. <br />
on Jul 21, 2011 | Computers & Internet
How to download ipod software to new ipod
Open iTunes on your computer and then attach your iPod. iTunes will recognize the iPod and if the software needs to be updated it will tell you. It will tell you if there are updates every time you connect the iPod. Once your iPod shows up in iTunes then you can program it with the songs/playlists/apps/movies/photos, etc., that you want it to sync.
Dec 25, 2009 | Apple iPod touch
I touch error 13
Ok, this problem usually occurs after you have tried to update your iPod to the 2.0 software. So here's what you need to do.
1. Plug your iPod into your computer.
2. Open iTunes.
3. Hold down the middle button and the Menu button, this is will help the computer recognize it.
4. Once it does, click the iPod icon in iTunes.
5. Now click "Restore." This will pull all the software off the iPod and put the latest Software on it.
Hope this helps! -cj
Aug 16, 2009 | Apple iPod touch
My ipod touch is locked and i forgot the passcode and its disabled and i cant link it up to itunes unless i unlock it which i cant
Updating and Restoring iPod touch Software You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch. ââ If you update, the iPod touch software is updated but your downloaded applications, settings, and songs are not affected. ââ If you restore, the latest version of iPod touch software is reinstalled, default settings are restored, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. In iTunes 7.7, you can also restore from a backup without deleting data stored on iPod touch. Note: Deleted data is no longer accessible via the iPod touch user interface, but is not permanently erased from your iPod touch until it is overwritten by new data. For information about permanently erasing all content and settings, see “Resetting iPod touch” on page 94. Update or restore iPod touch: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2 Connect iPod touch to your computer. 3 Select iPod touch in the iTunes sidebar and click the Summary tab. 4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available. 5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
May 07, 2009 | Apple iPod touch
My sons Ipod touch is passcode locked
it dosnt reconize it because its new and the itunes that you have is old
Dec 28, 2008 | Apple iPod touch
Bling Software Podmaxx 09 for PC Logo
29 people viewed this question
Top Bling Software Computers & Internet Experts
steve morris
steve morris
Edward Talavera
Edward Talavera
Are you a Bling Software Computer and Internet Expert? Answer questions, earn points and help others
