Question about Danby DDR3009EE Dehumidifier
Bucket full indicator light keeps coming on and the bucket is empty. I've reinserted the bucket many times thinking it's was inserted wrong but I still can't get it to work. The dehumidifier is brand new and only runs for a few seconds, then the bucket full indicator light comes on and it stops. What am I doing wrong? I have a Danby Premiere Model DDR30E.
  • Danby Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Apr 23, 2011
Flashing light is on(power on/off pad)
red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
The light indicating that "bucket
This usually happens when either the Float Valve in the bucket is stuck in the UP position (if yours is so equipped. Jiggle it to get it to return to the DOWN position.
If you humidifier's bucket is not so equipped. It's usually an indication that the bucket was not reinstalled properly, after it was removed. To check and correct this, turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and reinsert it, making sure that it fits "squarely" in the bucket holder from Top to Bottom. Once installed, make sure the bottom of the bucket is not tilted down in any way. Plug the unit back in and turn the Master ON/OFF Switch to ON. If it was reinstalled correctly, the bucket full light should have gone off and the unit will run as it should, if the humidity extraction level is set low enough.
Hope this helped you to troubleshoot and solve the problem.
Jun 23, 2011 | LG LD40E Dehumidifier
I noticed that the "bucket full" light is on and
heatman101
Mar 31, 2011 | Comfort-Aire BHD-651 Dehumidifier
Dehumidifier is saying bucket is full but it is empty
Here is a tip that I wrote to help people with just that dehumidifier problem..
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Mar 30, 2010 | LG LHD65EBL Dehumidifier
The bucket full light blinks even though it is empty and there is "01" in the screen where the digital humidity level is indicated. Pushing the up or down arrow does not change the "01" number. Unit won't...
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
Jan 02, 2010 | Kenmore 54701 Dehumidifier
Danby DDR3009EE Dehumidifier Logo
692 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
