Question about Cameras
When I turn on the camera everything seems to be working but when I try to take a picture it flashes normally as if it took a picture but then I don't get anything on SD card and no picture review then the LCD turns off but the eye viewer everything is on but then try to snap another picture it does nothing like it's turned off. thanks
  • Cameras Master
  • 19,396 Answers
Hi.
Some camera can save to internal memory. That doesn't seem the problem from description, but have a look.
If the camera snaps pictures that are all dark, blurred of white, then the camera is faulty. Depending on the case you get image sensor, board failure, lens etc.
If you shoot and the camera does not take picture at all, no file, try first replacing memory card.
If that does not work, try resetting the camera. That depends on the model.
If the camera is faulty you can get a quote here: Repair
Posted on Apr 10, 2011
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Black screen when trying to take pictures
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Apr 02, 2008 | Kodak EasyShare C643 Digital Camera
Camara powers on but will not snap picture!
did you just try to press the shutter button halfway?if yes...press in all the way through...if still does not take a picture..master reset...
-press menu
-press right to go to setup
-go down to reset
-highlight yes then press menu to ok it
-turn off then on then try to take a picture
hope it will help...(",
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
Flash
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Apr 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
