Question about Cooper Wiring Devices Combination Switch & Receptacle
I am hooking up a light switch have to black and to white what do i do put the black to the switch and the black togather?
  • 565 Answers
There are two screws on the switch. Connect a black to a screw on the switch, it doesn't matter which black wire or to which screw, pick one. The other black wire is connected to the remaining screw. Both white wires are twisted together under a wirenut and are not connected to the switch.
Posted on Apr 11, 2011
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
How to wire light switch?
ok! only hook up the switch to the black wires and cap the 2 whites together. just run 12/2 wiring with ground to switch, hook the black to switch in and black to switch out to light.. cap the white wires to and from switch! you can either hook ground wire to switch or the steel switch box. hope this helps, im not very good with words.
May 04, 2012 | Cars & Trucks
Have dual light switches - one for fan one for lights on fan. incoming to box is white (neutral) black(hot) then out to switches two sets of w/b. fan has one each of the white, black blue(lights). How do...
From your switch box to your fan run a 14/3 wire. Take the incoming 14/2 white wire,and connect to white of the 14/3 wire to fan lite combo ,and hook both white wires from fan and lite. Hook the fan black wire to the black wire from the 14/3 Hook the black wire from the fan to the red wire from the 14/3. Then go back to the switches, and add a black and red pigtail about 4"long to the black wire from the 14/2, now connect the red wire to one side of switch, and the other red wire from the 14/3 to the other side of switch. Do the same to the black wire on the other switch.
Sep 17, 2011 | Garden
I have a Leviton single pole rocker switch grnd, pilot light back and side wired #5628-2W i am trying to hook it up so light is on when switch is on i have 2 black wires 2 white wires and 1 ground wire how...
easy one first: ground wire to green screw. We have to assume the two black wires are the hot(coming from power source) and switch leg(going to light). Switch will have two brass colored screws. Looking at the switch with the off/on markings right side up. Put hot wire on upper screw and switch leg on other brass screw, With nothing hooked up, the hot wire will be the only wire with voltage on it. You can buy a non-contact voltage tester at Lowes or any place that sells electrical supplies. Now we must assume the two white wires are neutrals(one coming from power source and one going to light. The pilot light part of the switch will either have a silver colored screw or a white pigtail on it. all whites hook together. The pilot light is wired internally to the switch leg. Your switch should work properly now.
Jan 28, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
4 lamp t5 fixture, 1 black wire, 1 white wire, 1 red wire. how do I wire this
Don't forget this is a 240v appliance so it must be fed from a 240v circuit breaker. Once you have a 240v circuit breaker you need to run 12/3 wire with ground from circuit breaker to a box near your fixture. The 12/3 wire with ground will have; 1 black, 1 white, 1 red and a bare ground wire. With the circuit breaker OFF, hook the wires up respectively to the same colors and ground the bare wires togather with a green ground screw in the box. Turn circuit breaker on.
Nov 25, 2010 | Solar Flare Vho T5 4ft 8 Lamp Fluoro Grow...
I can't figure out how to wire my cooper wiring combo switch/receptacle. I have a white, black and copper wire coming in. One terminal on the receptacle side is clearly marked white/blanco, the two...
Take the black going to the light off the center and hook where the white going to the light is now....then hook the white to the light with the other white and you will be good to go...You almost had it right...
just a couple of adjustments....:-)
heatman101
Oct 11, 2010 | Cooper Industries Cooper Wiring 274W...
Two function control switch. Broan nu-tone
Oh Boy! ...Oh Boy! Lol...:) Put the Earth/Ground, (usually green and yellow) wire in the on screw side.
Then, get the Fan's black wire, and connect with the Light's white wire,...then put it in the any one of the Screws, (usually a hole where you put a wire through and screw down to hold. Golden ~ like in color).
Then, get the other Fan's white wire, and connect with the Light's black wire, then put in the other Screw hole. :)
And Whala :)
Mar 28, 2010 | Broan-NuTone FAN CONTROL SWITCH
I removed an old fan/light combo from my bathroom and put a new one in. The wiring comes off two switches wired together (3 wires total) and I need to know how to wire to the new fan/light combo. There is...
Hook the black wire from one switch to the fan and the black wire from the other to the light. Then hook all of the white wires together.
This will get you working like you want it too.
Heatman101
Feb 23, 2010 | Kitchen Appliances - Others
WIRING DIAGRAM
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Pull on/off switch
Put one wire from switch to black wiring coming in and the other to the black going to the ballast.
If you do not understand please post back
Dec 01, 2008 | Electric Door Light Switch
Cooper Wiring Devices Combination Switch & Receptacle Logo
116 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
