Question about Banner Plumbing
I have a banner 3 handle tub/shower faucet. I am trying to fix the center diverter valve. Now, when turning on the tub, I have good pressure but little to no pressure to the shower. Why? What is the remedy? How do I install the diverter so that I get the same "good" water pressure to both the tub (when I want to draw a bath) and the shower (when I want a shower)? I just now took it apart and the way I have the valve set right now I only get water from the shower and if I turn the diverter then I get no water flowing at all from anywhere!
    Sergeant:
  • 295 Answers
1. Check that you are not turning the diverter too far or not far enough in the SHOWER direction.
2. It's possible that the the center part of the diverter that shuttles between ling up with the TUB hole or the SHOWER hole is installed backwards. In the SHOWER position the water pressure keeps it in the SHOWER position and when water pressure drops it defaults to the TUB position. When installed wrong, the water pressure pushes it to the TUB position.
Hopes this helps. Let me know via message or rating (if helpful)
Posted on May 03, 2017
    Top Expert:
  • Banner Master
  • 39,415 Answers
The diverter probably is clogged with mineral deposits
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
SOURCE: just installed shower and faucet in bath tub when
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Posted on Mar 16, 2009
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
Shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
May 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Aug 31, 2009 | Delta & Single Handle Shower Faucet
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Plumbing Logo
71 people viewed this question
Top Banner Plumbing Experts
Mike
vince
Tom Chichester
Are you a Banner Plumbing Expert? Answer questions, earn points and help others
