Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
For lift master 976 keypad: I cant seem to delete the current password for the keypad entry. It allows me to change to a new password but it retains the original password as well. Even when I do it by pressing the smart learn button. P.S. I have not set any temporary passcodes.
    President:
  • 3,197 Answers
If you press and hold the smart/learn button for 6 seconds it should erase the memory and none of your remote unit should work. Just remember you will have to program them all.
Posted on Apr 11, 2011
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
Lift-master 1280 Keyless entry pad not working.
Is it possible the wiring to it backed out of the connections on the opener? Might check there first to see if it became disconnected. If the wiring looks good then I would take the wiring off of the back of the keypad and touch them together to simulate a switch. If the door reacts then the keypad is bad.
Nov 24, 2012 | Cars & Trucks
How do i change the code on my schlage BE365. I want to delete my current one and add a new one
You confused me about which model-the FE575 or BE365 lock that you are dealing with, but that's no problem. The information for either can be found on the same page.
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Reprogramming FE575:
Scroll down to this heading on that page:
Electronic Security-Keypad Entry Flexlock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Reprogramming BE 365:
Electronic Security-Keypad Deadbolt BE365
This installation video (second item down) will be useful to allow you to disassemble it and view the sticker.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Jul 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Some reason keyless entry won't open my garage door. I have directions to change the code but, there is nothing in the manual if your code no longer works. I have changed the battery, pulled the plug on...
If that keypad quit after working since 1997 and a new battery didn't get it going it has just gone bad. The model number listed for your opener is now 53876.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lockedout before user acct. password window entry
so is your password blank?? or have you changed it to something you cant rememeber? did you create a restore disk (no one really does this so will be surprised if you have) you can try a password change boot disk (search online for this) but can't guarantee this method.
May 07, 2010 | Acer Computers & Internet
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
112 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
