Question about Poulan 14" Chainsaw
How do I tighten the chain? 14 poulan 3314 or something likw that...thanks!
  • 52 Answers
I dont want to be that guy that just links everyone to the answer, but in this case its easier for you to watch Vs me attempt to tell you correctly! Your should be very similar to adjust!
http://www.ehow.com/video_4419325_tighten-chain-chainsaw.html
Best Wishes and Good luck!
Posted on Apr 10, 2011
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Show me how to change clutch on 3314 p
Use a Poulan clutch tool and look at the clutch for the direction to rotate the clutch. There will be an arrow and It should be CCW
Sep 14, 2014 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Chain brake locked up on Poulan 3314
About all you can do when that happens is disassemble it and put it back together after a good cleaning and check for broken parts while you have it apart. Good luck.
Aug 31, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I have a 14" Poulan
Take off nut, remove bar and chain, turn adjusting screw counter clockwise, replace bar and chain tighten screw, replace nut.
Aug 31, 2011 | Poulan 14" Chainsaw
My chain saw will not start model #3314 14 inch I followed the directons on saw yet it will not start I also have the manual and followed the directions
How many hours on the unit?
Does it have spark?
Is it getting fuel?
Check the compression. If it has low compression it won't start.
Jul 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
What is the oil to gas ratio on Poulan 3314
Poulan and Poulan Pro chainsaws with 2-cycle engines require a 40:1 gas-to-oil ratio, which corresponds to 3.2 ounces of oil per gallon of gasoline.
Jun 15, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Woodshark poulan 14" slack chain
make sure the little tooth on the end of the adjuster for the chain is locked into the groove its supposed to go into and tighten it down.
Note: the chain is supposed to get loose on you but not as quickly as it is. maybe after an hour or so of cutting.
and as for it not cutting well, the chain may need sharpened.
if it has been sharpened once by someone than take it to someone esle if it is not satisfactory.
Jan 11, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
I have a Poulan 3314 saw that is only two weeks old. It works good until it's warmed up for about 20 minutes. Then, when you finish a cut and get off the throttle it dies. It always starts right up again....
The low side of carb setting needs to be shut down. Will speed the idle up and stop from overloading on fuel. Only one catch. It takes a special tool to adjust. Go to poulanpro.com for your nearest dealer.
Oct 28, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan 14" Chainsaw Logo
135 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
