Question about GE Washing Machines
I have a GE HE washer model WCVH6400 and it acts like it is stuck on a drain cycle. What could cause this?
  • 135 Answers
SOURCE: ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Posted on Apr 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
It could be anything from a bad belt to a bad clutch to a bad tranny. In my opinion this washer is not worth repairing.
Posted on Jan 09, 2009
  • 77 Answers
SOURCE: GE Washer Model WBSE3120B1WW
check the heating element.
Posted on Apr 26, 2009
SOURCE: GW Profile Washer Model WASE4220
The motor is bad. I just fixed one like this myself. The original motor has been superceded and the new one fixes the problem.
Posted on May 18, 2009
  • 111 Answers
SOURCE: GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Posted on Jul 15, 2009
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
I just had a new GE washer delivered to my home today, June 24, 2008. All it will do is fill with water and than drain. The agitator cycle does not work and the spin cycle does not work. Model...
We had the same problem with our new GE washer.......the repairman just left. It's the circuit board on the motor that failed, causing the motor to stop working. GE will replace it under warranty.
Jun 24, 2008 | GE Washing Machines
GE top load washer won't drain or spin
there was something stuck in the water pump. we pulled it out and good to go.
Jun 14, 2008 | Washing Machines
Ge washer model#wjsr2080t6ww
Apr 07, 2008 | Washing Machines
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
