WHEN I INSERT MY SDHC CARD INTO MY DELL PHOTO 944 PRINTER IT COMES BACK READING MEMORY CARD ERROR OR NOT COMPATIBLE ALTHOUGH I AM SURE I HAVE MANAGED THIS ACTION PREVIOUSLY?
    Sergeant:
    Champion:
  • 207 Answers
I have had that issue have you tried a different card, if the problem persist there something wrong with the insert dirty or damaged they normal give you a blank one that ant real too keep in there too keep it clean.
Posted on Apr 10, 2011
Pdr m700
Hi Lorinda,
There are a few different reasons why your camera may not be reading the memory card.
Troubleshooting such problems can be a little tricky, especially if no error message appears on your camera's screen.
The cause and solution may include one of the following:
    ·The card may not be the right type for the camera: First make sure the memory card you are using is compatible with your camera. For example, a SDHC memory card often will not work with older memory card readers. Even though SD memory cards are similar in size and shape to SDHC cards, they use different software for managing the card's data, meaning older readers sometimes cannot recognize the SDHC cards. Sometimes you can solve this issue by updating the memory card reader's firmware to give it the ability to deal with SDHC cards. Check the Web site of the manufacturer for your memory card reader to see if new firmware is available. It is also a good idea to check with your camera's manufacturer (on it's website) to see if an updated version of your camera's firmware is available.
    ·The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    ·The card or a file on the card may be corrupt. Photo file corruption can occur when the battery power is too low when writing a photo file to the card, or when the memory card is removed while the camera is writing a photo file to the card. One way to check if it is the card or your camera is to try moving the memory card to a computer, then try accessing the photo file directly from the computer to see if the file actually is corrupted, or if your camera is just unable to read a particular file.
    You can also double check this issue by using another memory card in your camera and see if it works as it should. If the memory card is unreadable on any device, the next step is to reformat the memory card. Look through your camera's on-screen menus to find a "format memory card" command. However, keep in mind that formatting the card will erase all photo files stored on it. Some cameras just work better with a memory card when that memory card is formatted inside the camera. If you do reformat the card, make sure to let the process finish itself before removing the card. Removing a card during formatting may damage the card.
May 01, 2014 | Toshiba PDR-3300 Digital Camera
I have a 4GB SD memory card that I am trying to use. It says the memory card is empty or incorrect file format. I have only 4 jpegs that I compressed thinking this was the problem. How do I get it to...
The problem is that your NuVue 560 Digital Photo Player is only compatible with SD cards, not SDHC cards. You bought a larger card for your older Digital Photo Player, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the Digital Photo Player is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. Ask around your friends: someone who has a camera that can use SDHC cards might have an older 2Gb card that they'd be willing to swap ;-)
Mar 21, 2011 | Digital Spectrum NuVue 560 56Inch Digital...
When I insert a SDHC memory card in printer,I get card access error message.How can I solve this problem?
Your printer was designed to use SD cards with a maximum 2GB capacity. It was not designed to be compatible with SDHC cards and cannot read them.
SDHC cards are a later development and will fit into the same slots, but are technically different. As the difference is due to hardware incompatibility, there is no way to update your printer to accept the later standard.
Jul 09, 2010 | HP Photosmart 375 InkJet Printer
I have a PNY Optima HD memory card and it will not read in my HP photo printer. Is there any way to fix this?
You don't specify your printer model. Check in your printer's specifications (either in the manual or online) if your printer is compatible with SDHC cards.
SDHC is a new generation of SD cards and older devices might not be compatible with this it.
Nov 27, 2009 | PNY 4GB Secure Digital High Capacity...
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
The printer will not read the sdhc memory card
You could try re-formatting the card and see if that helps. If not then check with HP to be sure you are using the correct type of card some of the high speed camera cards are not compatible with some brands of printers.
Aug 20, 2009 | Office Equipment & Supplies
MEMORY CARD ERROR
What photo printer are you using?
It might not be able to read the High Capacity Memory Card. Check the user manual it should say what size and type of memory cards it is compatible with.
Aug 04, 2009 | PNY 4GB Secure Digital High Capacity...
Wrong SD cards????
Your printer may have issues reading SDHC memory cards. The Secure Digital 2.0 standard (SDHC) is not backwards compatible and requires SDHC compatible devices in order to function.
http://www.promaster.com/support/cardreader/sdhc.asp
Jul 08, 2009 | Epson Stylus Photo R300 InkJet Printer
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Computers & Internet Logo
David Payne
David Payne
