Question about Kenmore 95012 / 95014 Electric Kitchen Range
I have a Kenmore electric range model # 665.95014.102. It is showing a red E2 (on left) and a green -F2- ( on right) error code. It does it while not using range and also sometimes while using the oven. I have unplugged the range and have reset it only to have it pop back up. Sometimes can use the oven for hours and days. Sometimes out of nowhere it comes on for no reason... It is 9 1/2 years old. Micro computer or oven sensor... would like to fix it ourself!
fridgetech
  • 473 Answers
SOURCE: Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Posted on Oct 23, 2007
aborcass
  • 2651 Answers
SOURCE: codes
F1 E1 N/A EEPROM checksum error Replace control no code posted for e2 f2
Posted on Mar 04, 2008
duby1990
  • 367 Answers
SOURCE: Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Posted on Nov 18, 2008
philbran
  • 242 Answers
SOURCE: kenmore oven and brolier will not work
The problem lies within your oven control board. This is very common and are not very hard to replace but they are expensive. You can check the price of a new control board at sears parts.
Posted on Dec 30, 2008
  • 272 Answers
SOURCE: Error code E2 F2
As you are aware the technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
E2 relates to an overheating condition. Quite possibly related to your touchpad issue. I'd try cleaning the contacts and if that doesn't work...Up to you at that point!
Good luck
Posted on Jun 01, 2009
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
How to change the door switch
Hello.
Some Washer ranges are equipped with electronic displays that indicate the time of day and the oven's temperature when it's in use. The display also alerts users to error codes including PF, or power failure, and various letter and number combinations that correspond to issues ranging from electronic control malfunctions to problems with the oven door latch.
Related Searches:
F2 Faults
Washer F2 faults relate to temperature problems in the oven. In the case of the error E2-F3, F2 is the general fault code and E2 is the specific error code. An E0-F2 error indicates that the oven's temperature sensor is open; E1-F2, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E2-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in "Clean" mode.
Clear Error Code
If your oven display shows a letter/number combination, washer advises clearing the display. Press "UPPER OFF" or "LOWER OFF" on double oven models. On single oven models, press "OFF/CANCEL" to clear the display. If the code reappears, the manufacturer recommends contacting a professional service technician or contacting the Washer producer
Professional Service
The Tech Sheet included with Whirlpool ovens is meant for use by professional technicians servicing the unit. To address an E2 F3 error, a technician can check the oven's temperature sensor connection, measure the sensor's resistance and, if necessary, replace the sensor.
Thanks.
Dec 07, 2011 | Washing Machines
91136669891 HAS ERROR CODE F2 F3
Are you sure about this error? The 91136669891 was made by Whirlpool for the Kenmore line. The 4 character codes for these ranges are F# E# (not two Fs).
Depending on which error you are actually have see below.
If the code includes F3 then you have a problem with the oven temperature sensor (F3 E2 would be temperature too high). You need to replace the sensor. Sears Parts Direct has the sensor for $74.12: http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Range-Parts/WB21X5301/0022/364/Model-91136669891/0582/0124250?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P9040087&diagramPageId=00005&productTypeId=x&searchModelNumber=91136669891&subCompDesc=Body&brandDesc=KENMORE&modelDesc=30 . The complete diagram of the oven parts is available here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00005?blt=06&prst=&shdMod= . The sensor is part 253.
If the code includes F2, then double check the second code. Whirlpool has no F2 E3 error that I know of. However, F2 errors tend to be a problem with the keypad. Check the wiring connection between the keypad and the control. This should be firm. Then press Cancel. If the error persists, you need to replace the keypad. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00001?blt=06&prst=&shdMod= for the parts diagram and prices.
I hope this helps.
Nov 23, 2011 | Kenmore Kitchen Ranges
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
I am getting a E2 F2 code on my kenmore electric range model 95014102, pressing the clear button does nothing, I unplugged the stove and the code went out for a few days it is back on. What could be the...
The E2 F2 is an indication that the oven got too hot and shut down. If the oven actually got too hot the issue is most likely the main control board. If the oven did not get too hot the problem would be the sensor.
May 08, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
I have a Kenmore Super Capacity with UltraBake System. Model number 92004102. I keep getting error message E2 F3 and my oven door locks and my oven turns off. What does this earor message mean?
We have parts for your Kenmore range. You have a series of 3 numbers before the model number that's on your range. Those numbers tell us who manufacured your oven. Once we have this information, we call tell you which part you need to stop the E2 F3 error codes.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST Monday through Saturday and we can get you cooking again!
We look forward to working with you and getting you up and running again soon.
Thanks, Ella
Dec 11, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Error code E2 F2
Good luck
Jun 01, 2009 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Good luck
Dec 18, 2008 | Kitchen Ranges
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Kenmore 95012 / 95014 Electric Kitchen Range Logo
79 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
