Question about Kenmore 43042 Front Load Washer
I have a Kenmore model 43042 frontloader. Recently, the outer drum piece was replaced by my ex-husband. After completing the repair, we ran an empty load and eveything worked great. Today, I went to do my first load of clothing and the washer stopped (no power at all) in mid-cycle. I tried to unplug and re-plug. I checked the breaker. I even tried smacking it, and nothing. HELP!
  • sbm081 Apr 10, 2011
    where is the fuse located? and there is no start button---only starts when you pull out the knob to start the cycle.
  • 4,399 Answers
Thanks for choosing FixYa and welcome to the site. You need to make sure your fuse did not blow in the washer. Make sure it is on the correct setting also. Push and hold in the start button and see if it comes on. You want to make sure the washer is getting power. You should check the outlet to be sure. With Kenmore, you may have a bad lid switch. They can get bent and not work right. It may be defective.
Posted on Apr 10, 2011
  • Richard Hale
    Richard Hale Apr 11, 2011
    The fuse is located on the control board. You will need to remove the panel to get to it.
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
How remove Kenmore frontload basket from rear shell?
this is a big job and prob spendy if not under a warranty......
the outer tubs are connected by metal fasteners which need to be removed by a flat screwdiver mark the old fron outer basket with a marker so u can replace those clips in the same manner..........to get acess to the tubs turn power off and remove top, remove back panel, remove front as well console bottom panel etc,,, disconnect all componets,bellows gasket ,connection wires, tubes, remove motor, undo bottom pump tube, remove belt and remove back bolt holding on pulley, get two people and remove tub out front when completed disasseblying all necessary pieces.. once tub out then remove those metal fasteners and set aside front tube reinstall onto new rear/inner rear tubs... hope this helps i might have forget some things actually i know i did this is a complicated process hope this helps let me know
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
How do you repair drum bearings
u must get the inner and outer tub parts, the bearings are actuallly a part of the outer tub assembly,, it is a pain a complete teardown usuallly people just buy a new unit,,, some units had 5yr part warrranties, common bill on a rear bearing install on frontload is usuallyy 600-900 dollars no joke..
Feb 03, 2010 | Kenmore 46462 Front Load Washer
My Kenmore front load 4304 washing machine tub
I would need the complete model # to get you a breakdown showing the piece i believe to be broken and in need of replacement. I believe this Kenmore F.L. was built by Frigidaire and they have had a problem with a specific piece on this machine. I will be glad to help once you get me the full model, should be around the opening of the door.
Oct 25, 2009 | Kenmore 43042 Front Load Washer
Kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Oct 01, 2009 | Kenmore 46462 Front Load Washer
Horrific banging when in the spin cycle
There are a series of balancing springs connected to the drum. It sounds as though one of them has come off or loosened. Yuo'll need to turn the machine on its side to find out. Good Luck! Let me know how you make out.
Jun 08, 2009 | Kenmore 43042 Front Load Washer
Kenmore front loader run with shipping bolts in
I would have sears replace the washer and also replace all the damage in your house. If it pulled out the drain hose there could be damage in there, if they are not willing to replace the machine then they should run a thorough diagnostic to make sure EVERYTHING is in working order, and still replace what is damaged to your house
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
Water leaking on floor after every wash
there should be an acess panel that your husband can remove(2 screws on either side of bottom of panel. From there you will get a bettter idea of where leak is coming from. might be as simple as a hole in a drain line. take a look
Mar 08, 2008 | Kenmore 43042 Front Load Washer
Kenmore Washing Machine doesn't rinse
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. Check as well that pump spins and clean from any clogged. Good luck!
Oct 08, 2006 | Kenmore 43042 Front Load Washer
Loud Noise - Spin Cycle
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 43042 Front Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
