CT sensor error Error code 092-310 error code 00002000 restart printer. please note will not restart also unpluged still no respond
    Sergeant:
  • 260 Answers
The CTD Unit is a Sensor on or near the Transfer Belt Unit on your Dell Laser Printer. This error is advising that the sensor is dirty and may need cleaned.
If you receive one of these errors please clean the CTD Sensor on the Printer.
  1. CBR Tech Solutions orhttp://www.cbrtechsolutions.com
Posted on Oct 22, 2015
fotomohamed
  • 321 Answers
SOURCE: Xerox 7132 error code 092-310
check out for loose connection
Posted on Jun 18, 2009
komguy
  • 2306 Answers
SOURCE: printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Posted on Jun 23, 2009
SOURCE: printer not activated, error code -30
I have fixed this problem, and I also know what caused it initially. First of all, this started happening after I installed software called WillMaker Plus 2009. For some reason, that installation also had created a new "Quicken PDF Printer." I think that was interfering with my default printer. So what I did, was completely unistall my default printer driver, turn the printer off, and then reinstall that specific driver from online. When I turned my printer on, my computer sensed new hardware, and took it from there. Fixed.
Posted on Aug 09, 2009
  • 1126 Answers
SOURCE: Printer error 6A80
6A80
6a90
c000
6C10 feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective.
Troubles with purge pump and or purge tube plugged (clogged). Needs service tech.
Posted on Nov 24, 2009
  • 34 Answers
SOURCE: We have a Dell 5110cn and we keep getting a
Follow the steps under "Cleaning the Automatic Density Control (CTD) Sensor" heading at the following link. If the problem persists after cleaning the sensor may be faulty and you will need to contact Dell for warranty support.
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Posted on Jan 21, 2010
What does error code 6910 mean on canon printer mg5440
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Apr 16, 2015 | Canon Office Equipment & Supplies
HOW DO I FIX ERROR 0X05
that an internet explorer problem try this (http://www.solvusoft.com/en/errors/runtime-errors/microsoft-corporation/internet-explorer/0x05-internet-explorer-8-error-code-0x05/
Oct 23, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
Ctd sensor error
The protection sheet on the imaging unit is probably still on, remove that and the error should go away.
for more help visit CBR Tech Solutions
Jul 11, 2013 | Xerox Office Equipment & Supplies
Error code 5700 turned off and unplugged. wont let me do anything
ASF sensor error or Error Code 5700
An error occurred in the ASF cam sensor.
Problems and Solutions:
Replace one of the following:
- ASF unit
- PE sensor board unit
- Logic board
This is hardware error and you need to show it service center. Following things you have to do.
- ASF unit
- Logic board
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon MX700 Office All-In-One InkJet...
UNABLE TO PRINT DOES NOT RESPOND TO TROUBLE SHOOTING PROVIDED IN USERS GUIDE THIS IS ONLY USED TO COPY AND SCAN & COPY
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 24, 2009 | Brother MFC-5840CN All-In-One InkJet...
Error code 5700.. already checked for jams, none, unpluging won't do it... none of the buttons respond... what else ??
Error 5700 is ASF sensor error.Check first the sheet feeder.If not have a jams the problem is in purge station.You can't fix it by yourself and your printer need repair.
Nov 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
Product : imageRUNNER C2880 / C3380 Title : E025 sub code 0002
Problem :
The machine is giving an error code of E025 with a sub code of 0002 indicating an error with the cyan toner motor.
Solution :
Replace the Process Kit Relay PCB. Item 58 of the Hopper Assembly circled below, part number FM2-8266-000. NOTE: the service manual refers to this part as the Process Kit Relay PCB while the parts catalog calls it the Connecting PCB Unit.
getfile.asp?rid=24817
Apr 27, 2009 | Office Equipment & Supplies
Canon Pixma MP780 gives no lights no response
There are no error code #300 to look up. Please check the error code again and repost and I'll try to help you out with this problem. However the is a #300 error for the fax, it's basically a wrong number was dialed.
You can get the Manual from Canon's website. www.usa.canon.com
Nov 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
Canon Pixma iP6000D Inkjet Photo Printer
this is all i could find out
ssue: ERROR LCD: Error code (5xxx through 9xxx)
Solution: Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Feb 19, 2007 | Canon Pixma iP6000D InkJet Photo Printer
258 people viewed this question
k24674
jasbo
jasbo
