Question about GE GSS22SGM Side by Side Refrigerator
How do I get to the defrost heater in a GE refrigerator model # GSS22JEPA?
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
Amigaman
  • 248 Answers
SOURCE: GE sxs Not Freezing
See if freezer fan is running when the unit is on. If you hear no fan when it's running. You probably need an evaporator fan motor.
Also check for ice or frost build up around fan.
Posted on Nov 14, 2007
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
  • 358 Answers
SOURCE: Testing if Fault is Comming From Defrost Heater
You check for continuity at each end of each heater.If is ok you have a bad defrost timer or abad defrost terminator(it 'll close when reaches about 30 degrees).
Posted on Apr 17, 2009
Sea Breeze
  • 4654 Answers
SOURCE: how to replace defrost heater ge refrigerator
Replacing the heater is not too big of a job. Unplug the refrigerator, remove the rear panel in the back of your freezer. Sometimes the ice maker and some of the shelf brackets need to be remove to be able to get the rear panel off. Then down below the evaporator you will see the old defrost heater with wires attached on each end. Disconnect the 2 end wires and look at how the old defrost heater was attached. You need to reattach the new heater on this holder or bracket depending on your model number. Put the new heater in and tighten the 2 wires on each end securely. Replace the rear panel and you're good to go. Thanks, Sea Breeze
Posted on Aug 21, 2009
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
Where is the defrost heater located in my GE Profile model TCS18?
defrost heater is located inside of ref. freezer take out shefs and racks.should be screws on back plate remove plate and derost heateris is normally mounter at bottom of coils .ge still uses glase heaters.google model no. for correct part
Apr 10, 2013 | Refrigerators
Wheres the heater conductor go on a ge model gts22jbpbrww and how does it attach to the defrost heater
GE defrost heater how to video:
Defrost termination thermostat replacement video:
more
Sep 24, 2011 | GE Refrigerators
Freezer coils are frozen up and the evaportation fan is working. Where is the defrost heater and what does it look like?
http://www.repairclinic.com/PartDetail/Defrost-Heater-Assembly/67001794/1022690 is what one looks like (since you didn't give your model number - couldn't look up the one you need)
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GTL21KBXABS/0432/0166000/G0904088/00002 It is item 58 on the diagram, but again not your exact schematic. The defrost heater is normally located very close to the coils.
But if you test your defrost heater and it is good (see video on first link on how to test) then you might have trouble with the thermistat - http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GTL21KBXABS/0432/0166000/G0904088/00002 or the timer - http://www.repairclinic.com/PartDetail/Defrost-Timer/482493/3348 and some whirlpools even have a defrost control board - http://www.repairclinic.com/PartDetail/Defrost-Control-Board/W10353224/1860724
Hope this helps!
Jun 10, 2011 | Whirlpool Refrigerators
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Model gss22jepa
i answered one problem like yours before, she told me, there's no way to remove the tray from the front nor from the rear.
she just pick up all the water using towels and tissues. she's just lucky to have small hands. she was very frustrated with the design where you can not remove the drain pan to clean it.
tnx 4 using fixya,
drcool
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model GSS22JEMB WW - Defrost heater Bad
yes, remove the freezer panel and defrost with blow dryer. will work for about 5 to 7 days.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE sxs Not Freezing
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
GE GSS22SGM Side by Side Refrigerator Logo
67 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
