Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
I have a Kenmore range C970-625481, serial beginning NF; I have been offered a GE GRCL3700VM-1, serial beginning VT. I like the idea of having convection, but it's not necessary. Which is the better stove and why?
2 Suggested Answers
  • 2841 Answers
SOURCE: WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Posted on Apr 25, 2010
I am trying to determine when my gas range was manufactured - 362-7585590 is the model number. And who manufactured it. Thank you.
The 362 code indicates that the range was made by GE. The manual for the range is available here: http://www.searspartsdirect.com/partsdirect/user-manuals/3627585590-kenmore-parts-gas+range-manual?manualIndex=0 . To download the manual go to http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0801065.pdf . You need the serial number of the range to determine the date of manufacture.
These sites may help: http://products.geappliances.com/appliance/gea-support-search-content?contentId=16195 and http://www.appliance411.com/service/date-code.php . The first site lists how GE adds the date code in the serial number. The second site will give you the manufacture date after you fill in all of the details.
I hope this helps.
(Some code lists indicate that the 362 prefix indicates a Roper appliance built with GE parts.)
Apr 07, 2017 | Kitchen Ranges
Kenmore c970
I would suggest not operating it and turning off the main breaker or pull the fuse for the unit, this could be a fire hazzard I would get a service tec to check it out. It sounds like a broken neutral. I do not know the unit so this is just a guess.
Apr 08, 2014 | Kitchen Ranges
Don't know how to use the self-clean controls Model C970-535121 serial # NF-40611012
The knob for the oven should have a setting for self cleaning, just turn it on and walk away for a few hours!
Dec 29, 2012 | Kenmore 91112 / 91114 / 91117 Electric...
GE Control Valve Problem
Call 1-800-GE CARES. If it's under warranty free fix probably, if not, make them know it's a hazard. Sorry not much help,
Dec 16, 2011 | GE Kitchen Ranges
Broiler not working. How can I replace the fuses if that is the problem? Kenmore Range bought in 2002. Model C970-595081 Serial NF 2171 0264?
the model number you sent doesn't come up,is it gas or electric?if it's gas most likely it will be an ignitor.if it's electric probably the element.send correct model number off the machine,open the bottom draw,look at the left or right part of the frame and you'll see a tag with the model and serial numbers,just need the model
Mar 06, 2011 | Kenmore Kitchen Ranges
Need owners instruction manual to turn on clock on kenmore range
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.########
Using that format, try the Sears Parts site where (on the right of the components page) there may be a section for getting a manual,
http://www.searspartsdirect.com/partsdirect/index.action
Otherwise, use the Sears Answer Site for manuals.
http://www.managemyhome.com/
Nov 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
2001-2002 GE Spectra XL44 Gas Range Parts search
it is your lucky day.....I have 4 grates/burners in gray .....make an offer before I put them on Ebay.
May 17, 2008 | Kitchen Ranges
Clock doesn't work
go to your nameplate and get your complete mo No and serial No. those mo No s you are giving are off of your use and care manual. --they are not complete mo No. WHAT IS YOUR MO No AND SERIAL No?????
Jan 13, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Problem with a different range...
Tom, generally a f1 code implies a control problem. The tech sheet gives 3 possible causes. 1. A shorted keypad, solution to replace electronic control. 2. Controls internal checksum has become corrupt, solution is to unplug for 30 seconds, if the code comes back, replace the electronic control. 3. Control has sensed a overheating condition, relay on the board may have shorted out. Each one recommends replacing the control board. The part I have for this model number is 316127903. Says it's grey. Catriver..post back.
Oct 24, 2006 | Kenmore 79383 Dual Fuel (Electric and Gas)...
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
37 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Freddy
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
