Question about Mantis 2-Cycle Tiller
Having problem starting tiller - Mantis 2-Cycle Tiller
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
I have a Mantis Tiller. It starts but has no torq...
possibly the (muffler) is plugged with carbon. happens when too much oil is used
May 19, 2010 | Mantis Tiller
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Cord is frozen and tiller won't start
take pull rope cover off and oil the clutch that screws on the crank shaft
Apr 24, 2009 | Mantis Tiller
In order to start my tiller up the tines have to engaged
no,it sounds like the wires on the neutral safety switch need to be changed or the switch is bad
Apr 23, 2009 | Agri-Fab Agri Fab Universal Tow Behind...
Mantis 2-Cycle Tiller Logo
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
