Question about Hayward Northstar Pool Pump 2 Hp Sp4020ns
Noisy chattering sound,. leaking water, still works good
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel.
Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 11, 2011
Loud chatter on start and rattle from timing chain area
The timing chain area also takes in the alternator and water pump. To isolate the source of the noise, use the old mechanics trick.
Place a 3 foot 1/4 inch brass rod against the flap at the opening of your ear and push until it closes. Place the other end of the rod against various engine components and listen. The noisy problem will conduct the noise up the rod to your ear and you can hear quite precisely where the problem is. Much safer than laying your ear all over a running engine.
You can also loosen the fan belt and run the engine without alternator or water pump (briefly) to see how that affects the problem. Chatter on start makes me think of starter and Bendix gear problems. Sounds like a 2 person diagnostic team to me; one to start the car and one to listen and probe.
Don't know if Subaru Forrester has an engine that has valve interference at piston Top Dead Center. If it is and the timing chain breaks, you are looking at major $$ to recover.
Nov 06, 2012 | 2004 Subaru Forester
My admiral AAV7000AWW washer makes a loud chattering noise and leaks water..An solutions?Thanks a bunch
Chattering could be a shaft bearing and if it got bad enough could have damaged the tub seal and makes it leak. attached is a price on parts if your interested
http://www.appliancepartspros.com/07-tub-parts-for-admiral-aav7000aww.html
Jan 07, 2012 | Whirlpool Cabrio Washing Machines
I keep adding water no signs off leaks water pump is noisy but not leaking could its still be the pump?
if the water pump is noisy it should be replaced anyways.it could be the pump that is leaking and not noticable.the system should be pressure tested and inspected to see were a leak could be.
Nov 01, 2011 | 1999 Buick LeSabre
Loud sound from engine - steam from engine - leaking coolant - still starts, but noisy
Sound like the bearing in your water pump is clanking. Get the timing belt changed the same time as your water pump.
Jun 15, 2010 | 1992 Honda Civic
Motor is very noisy
Noisy motor indicates bearings on the shaft are going bad. This happens when you have a shaft seal leak and the leaking water is getting to the bearings. Sounds like you need to replace shaft seal and set of shaft bearings. Easy fix is to replace the motor only for about $150.00 for motor replacement. Around $40.00 for seal and bearings and some of your time.
May 31, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Leak with heavy load
Is the machne noisy? If not, it may soon become noisy. Sounds as if the grease seal protecting the basket spindle bearings is leaking. soon the bearings will fail
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
4wd noise on dry road
Shouldn't be too noisy but don't run it on hard dry pavement not good on a 4x4 put on lift or jack stands check all halfshafts, u-joints and fluid levels
Aug 07, 2009 | 2001 Dodge Dakota
Clattering sound when a/c is on and accelerating. goes away when i turn the a/c off. Clattering is under the hood, but i can't locate it.
Sounds like the a/c compressor has internal damage .
I would take to a shop , Let them diagnose it by recharge the system with dye. Then check for leaks, The orfice tube has a small filter in it. IF the filter is clogged with metal shavings the compressor is damaged internally. The correct repair will be a compressor, drier and expansion tube or orfice tube.
Good luck .
Jul 14, 2009 | 2002 Chevrolet Silverado 2500HD
Water leaks during brew cycle
you have a split in or a loose conection where the water pipe conects to the boiler so water comes from there and the lack of pressure is making the machine work harder which makes it sound bad
Dec 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Hayward Northstar Pool Pump 2 Hp Sp4020ns Logo
95 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
