Question about Garmin Nuvi 760 Car GPS Receiver
Device won't switch on either manually or in car connection. could it need a new fuse? I turned it off, disconnected from car connection and haven't been able to switch in on since. (I use the bluetooth for hands free mobile). Look forward to HELP! thanks Jane
  • 1,514 Answers
It may need a new fuse. The fuse is in the plug that goes into the cigarette lighter socket. To get at it you unscrew the silver ring at the end of the plug. Be careful not to lose the silver tip which can fall out once it's opened. When you take the ring off the plug comes apart. Take out the fuse and replace it with a similar one which you can get from any car accessory shop. When you have replaced the fuse you'll need to charge the battery for a while before turning it on.
I hope this solves your problem.
Posted on Apr 11, 2011
My suzuki s83 2006 won't start. I replace the battery, and new gas and Clean the carbs. Gas is getting to the carbs. New spark plugs . It turns over but dosent run.
Hi, Matt and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2, TPS, ETP, IAC,or BAS).
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box if applicable.
17. Tilt sensor needs a reset.
18. Security system not disarming alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
s50 starting problems
Won start 2005 suzuki s50 Suzuki Forum Suzuki Enthusiast Forums
2005 Suzuki Boulevard Cranks but won start Fixxit
Suzuki VS1400 Owner Manual
1988 1993 Suzuki Intruder Boulevard VS 1400 Repair Manual Download Manuals...
Jul 04, 2016 | Suzuki Motorcycles
Motor won turn over
The starter might be bad or you might need a new switch there are fuses but you would need to know what ones to check...
Apr 08, 2013 | 2002 Ford Explorer
2007 yamaha stratoliner won't start
Hi, William and the usual suspects are:
1. Fuel tank empty.
7. Fuel line to the carburetor or throttle body pinched or kinked.
10. Severely discharged or damaged battery you need 12.5 volts or better and be able to pass a load test if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
Bike won start Help the newb
What to do When Your Motorcycle Won Start
Yamaha XV19SW Service Manual
OEM parts for Yamaha
Yamaha ROADLINER XV19SW Owner Manual
Jan 10, 2013 | 2011 Yamaha Stratoliner
Toyota 4 Runner park lights won't turn off
faulty connection ,or check all your fuses from box,check fog lights fuse 1st,
Oct 29, 2012 | Toyota Cars & Trucks
The stand by button is flashing and wont turn on
1. take out from supply ,by take out power cord from outlet
2 reconnect power suplly and switch on,manually if needed, and then do hard reset,as is written in factory manual ( turn back to factory settings)
3 if that not help ,disconnect last connected device,or all and try again
4 check one more time power line voltage on outlet, , voltage selector on back plate on device, and for test purpose only connect ur AV Receiver plug directlly to outlet,without any extension cords with other outlets or devices on them ,as that can be source of problem ,too.(power,or voltage drop bellow point that is needed for this power drawing device to be switched on)
5 also disconnect for test purpose dig coax,and or antenna inputs..best is to disconnect all,and connect in directlly to power line outlet,and then to try hard reset to factory settings.
Sep 11, 2012 | Pioneer VSX-D912 Receiver
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
1995 e350 ignition fuse keeps blowing
You could just have a bad Ignition switch. It is not very expensive and is easy to change. If the new switch does not help you will have to trace down the wires from it.
Sometimes if you have a tilt wheel the wires break and ground out in the column. Most other controls are separately fused and the weaker fuse blows first. That kind of divides things up in the fuse panel to fuses heavier than the Ignition fuse. Also, if your Owners manual shows the Ignition sharing a fuse with another device, look at that other device for problems.
If you still have not found the problem its time to disconnect the Battery and use an Ohmmeter to find the grounded wire. When you find the grounded connection, the Ohmmeter will Zero out when you eliminate the bad connection.
Oct 22, 2010 | 1995 Ford Econoline
Battery wont stay charged overnight. Has new battery. Truck has 9992 mi. Alternator charging correctly.Seems to be electrical draw while truck is parked. No lights on.
WHEN YOU CONNECT THE BATTERY SEE IF YOU SEE A SPARK,IF SO THEN SOMETHING IS DRAINGING THE BATTERY ,DO THIS IN THE DARK,YOU MIGHT NEED A HIGHER OUTPUT ALTERNATOR
Oct 28, 2009 | 1995 Chevrolet Silverado 2500
Electrical problem
When you are disconnecting the low pressure switch, or high pressure switch, you are stopping the power going to the A/C clutch. So, that means that your A/C clutch is shorted out. Unplug the compressor, and see if the fuse blows.If it doesn't you need a new clutch or compressor.
Sep 06, 2008 | 1994 Dodge Caravan
Garmin Nuvi 760  Car GPS Receiver Logo
100 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
