Question about Water Pentair 520543 EasyTouch 4SC-IC40 Control System, Almond
My easy touch 4 system is giving me an error code with respect to the pool water temperature. The temperature has not varied for several weeks now at all. Is there a way to reset or recalibrate the temperature indicator? Thanks for your prompt response. Rich Nay.
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater throws code h5? smoked
HS
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees.
Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow conditon. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater...
New heater was left dry for 4 weeks while spa pump was replaced. turned back on with error code Fault-shorted H20 Sensor. is it truly in need of replacement or can it be cleaned after sitting and rusting?
You can put an ohm meter on the two wires of the temp sensor and see how much resistance you get. I can't find the chart right now but you should read about 15,000 ohms at a water temp of 88 degrees. Resistance drops as temp rises. A "short" will give you the same result as just holding the two test leads together.
Having the heater idle for a few weeks should not have affected anything. The temp sensor isn't too hard to change yourself if needed.
Sep 15, 2013 | Jandy Lxi Heater Temperature Sensor...
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
Have pentair easy touch controls just installed new water temp sensor. spa is 88 degrees but master temp heater shuts off because it reads 104. what should i check? the thermistor/
If the Easy Touch is reading the correct temperature, but the heater is not - you need to double check the temperature of the pool water with a standard pool thermometer.
Other things to consider:
1) The water is traveling too slowly through the heater. If the water is heating too quickly, then it will shut it off. If it takes a while for this to occur, then this would not be the issue.
2) Thermostat/thermistor is incorrectly reading the temperature of the water prematurely shutting the system down.
Make sure you really are checking the temperature of the water and matching this temperature up with one of the two readings that you are getting. Don't just take the word of the displays on either unit.
Dec 10, 2010 | Pentair Mastertemp Heater
New Pool Heater not igniting on demand
if wired 120 volt make sure to check wiring red and black wires need to be changed ignitor not getting enough voltage
May 30, 2010 | Jandy ZODIAC LEGACY HEATER 400KBTU...
Aqualink RS4 Water temperature reads 120 - obviously wrong.
No but this sensor is easy to replace. Just pull the sensor from the pipe by loosening the staniless steel clamp that holds it in the pipe. Then follow the wire back into the Aqualink box and unplug. Get a new one at your local store and replace. It's a common problem and you should be able to do it with ease.
May 21, 2010 | Jandy Aqualink Rs4 One Touch Control...
Water temperature thermostat misread
You most likely have a bad water temperature sensor. Replace the water temperature sensor that is probably near the discharge side of the filter pump. That should take care of the problem.
Oct 17, 2009 | Pentair Easy Touch Indoor Control Panel...
Huge temperature variation in Chateau by Moen shower only faucet
You bet....Pressure at the building varys with large use...8-10am or 4-6 pm....What floor you on...Higher the more pressure you need...maybe a pump...or plugged press.balance system....Not a novice handyman job...
Aug 13, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Water Pentair 520543 EasyTouch 4SC-IC40 Control System, Almond Logo
44 people viewed this question
Top Water Home Security Experts
Lawrence Oravetz
Are you a Water Home Security Expert? Answer questions, earn points and help others
