This would depend on which OS you are trying to install. Also, if the system booted before and you are receiving this message you probably have a bad hard drive or corrupted system files. There are free operating systems out there such as Unix and Linux, or you can go through Microsoft and get the OEM disc for your preferred operating system. If you do not want to puchase the OEM disc yourself then you can also go through a pc repair shop and have them do an OS reinstall. Hope this helps, let me know if I can assist you with anything else.
You will need a operating
system disk or a repair disk to fix it. Insert it in the drive then boot
from it. You want to get to a dos command prompt (black screen with white
lettering) and type the following commands. Press ENTER after each
command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos
command prompt and run the check disk utility.
To
run the check disk utility you will need a repair disc or a operating system
disc. Put the disc in the cd drive and boot from it. You want to
get to the Dos Command Prompt (Black screen with white letters) and type the
following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
