Question about Coleman Roadtrip Grill LXE 9949-750
New grill won't light. Not getting any gas. Roadtrip model 9949A.
    Brigadier General:
  • 4,736 Answers
Assuming your tank is a least half full - Turn the tank Valve to OFF. Disconnect the hose from the tank and wait 5 -minutes. Then reconnect the hose to the tank and turn the tank valve ON VERY,VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open light the burner farthest from the tank first and once it's lit, turn it to HIGH. Light the remaining burner(s) the same way. Does the flame height look as it should? If so, you solved the problem. If not, you'll need to replace the grill hose/regulator assembly. If that's necessary, since your grill is new, the warranty should cover it. Just make sure you have your Proof of Purchase.
Hope this helps you solve the problem. Happy Grilling!!
Posted on Apr 10, 2011
Problem starting coleman roadtrip grill 9941768
Make sure the igniter is not being covered in grease and not sparking. Also, if you had it stored, make sure a tiny critter has not taken up residence in one of the Gas tubes feeding the burner
Jun 13, 2014 | Coleman Roadtrip Grill LXE 9949-750
One side of my grill does not light. The other burner lights just fine. How do I fix this? Is. There a place I can bring it for repair?
If you stored it outside, chances are an insect took residence in the gas tube. It is rather hard, but you can remove the 6 screws holding the crome surface from the body of the grill. With this removed, you will be able to see if the gas passages are clear. You can even remove the gas jet ans make sure it is not plugged up.
Jul 25, 2012 | Coleman Roadtrip Grill LXE 9949-750
I have a Coleman Roadtrip XLE. The on/off knobs do not control the gas. The gas comes on FULL bore and give a LARGE flame.
The problem you're having could be the result of a faulty regulator. Replacing the Hose/Regulator Assembly should solve the problem. You can pick one up at any home center or hardware store that sell grills and accessories for about $30.00.
Hope this helped you and happy grilling. Thanks for choosing FixYa.
Aug 22, 2011 | Coleman Roadtrip Grill LXE 9949-750
My Coleman roadtrip cooks way too hot. Is there a way to turn down the flow. We are burnig on low.
If you're cooking at the lowest setting and the flames are to high, you will need to replace the gas control valve for the burners. Coleman still stocks some parts for your model. Appliance Factory Parts carries a wider selection of parts. http://www.appliancefactoryparts.com/
I hope this helps. Happy Grilling!!
Jul 14, 2011 | Coleman Roadtrip Grill LXE 9949-750
New propane tank. Burner will not light, no gas flow. This was a replacement grill from coleman because they couldn't get the regulator. Starting to get very disgusted with this product.
jcw - It sounds like the regulator is locked up from turning on the gas tank valve. Happens a lot with the new OPD Valves on the grill tanks.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Jun 18, 2011 | Coleman RoadTrip 9928-A50 Propane Grill
I just bought a new roadtrip grill. I put it together, put a new tank in. The flame is barely visible. Is there an easy way to fix this?
Layla, it's a a common problem and one that's easy to fix. Turn OFF the tank valve and if you're using a 20 lb LP Gas Grill Tank, disconnect the hose from the tank If you're using an insert-able gas tank remove it from the grill. In either case, leave the gas disconnected for 5 minutes, Then reattach the hose or reinsert the tan and turn the tank valve ON VERY, VERY Slowly (Slow motion, slow). Once the valve is fully open, light the burner and turn the flame to the highest setting. Does the flame height now, look correct? If so, light any remaining burners the same way and check their flame height. If they all look correct, you've solved the problem. If not, the gas regulator/hose assembly (if you're using the 20 lb tank) needs to be replaced. If you're using the insert-able canister, just the regulator needs to be replaced. Either way, you're fortunate that your grill is new and still under warranty.
Contact Coleman Customer Service 800-835-3278 for free replacement parts or the nearest service center to you.
Hope this helped you. Please let me know. Thanks
May 06, 2011 | Coleman Roadtrip Grill LXE 9949-750
We've had our roadtrip lxe for 3 yrs. We live in Tucson Az. and it works fine here. When we go to the mts. in northern Az. it has failed us every time (9 times). It will light and run for about 15...
Gary & Millie, the mountains you're visiting, must be over 2000 feet above sea level and that's what's affecting your gas grill.The lower oxygen level and lower air pressure affects propane fueled grills. On larger gas appliances, the gas pressure can be adjusted to overcome this problem. But, I don't believe you can do that on a portable gas grill. My best suggestion is to contact Coleman Customer Support at 800-835-3278, to find out if they have another regulator that can be used in high altitude applications.
Good luck and Happy Grilling!!
Apr 19, 2011 | Coleman Roadtrip Grill LXE 9949-750
I just took my coleman grill out for the season and I don't get any propane to the burners. What now?
there may be a problem with the gas regulator,also make sure that the hole in the gas rails are clean form any soot build up
May 19, 2010 | Coleman Roadtrip Grill LXE 9949-750
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Coleman Roadtrip Grill LXE 9949-750 Logo
705 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
