Question about EuroTech Washing Machines
Hi, I just purchased a Eurotag Washer/Dryer (model XQG70-DA112PE) adn it washes perfectly but when wantign to dry clothes it works for about 4min and thens switches off and reads error code 12 and this we can't find in the manual. Can you help please? Tahnsk Kerry
SOURCE: washes clothes fine, drying cycle no heat
Hi, I have a Hotpoint WD640 myself and funnily enough I have the same problem. Knowing a tiny bit about washing machines you will probably find that your heating element from the dryer has stopped working. If you can still wash clothes that means that your other heating element for the washing is fine and that your thermostat for the machine is also working. If you need to buy a dryer component may I suggest 4hotpoint.co.uk, I have just bought an element from them and it cost me £27.99 including tax and P&P. May I also suggest that you get a suitably qualified or competant (not saying that you are not) person to fit the element for you as you do not want anything to go wrong with your washing machine. Hope this helps :o)
Posted on Jan 09, 2007
Hi, we had the same problem with a WD420P. After a washing machine repair man plugged in the diagnostic machine and found that there was no fault, my boyfriend had a look. The nut securing the cooling fan inside the heater element was not tight so the heater overheated and tripped it's stat. This was a 5 month old part fitted after the original was replaced under warranty.
Posted on Jan 14, 2008
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
  • 5184 Answers
SOURCE: how do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Posted on Jul 12, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Posted on Jan 08, 2009
Rank arena washer dryer
hello how do i get the dryer to work on the
  • Brand Name: Rank Arena
  • Model: XQG70-DA112PE
Jul 18, 2013 | Televison & Video
I have jst purchased this washer today, however the dryer takes ages,,,,,,their seems to be water going in when its drying, clothes come out hot, but still as damp as when i put them into dry.
Hi, this is normal for a washer dryer, water isn't actually going in, it is condensating and then being pumped away.
when you use the dryer program your are only meant to put half the washing load or less in at a time if there is too much wet washing in the machine it will take forever to dry as it cant get rid of the amount of condensation quick enough so some of it is reabsorbed into the clothes and so it goes on.
so the trick is only to put in a maximum of half the full washing load.
Hope this helps.
Feb 11, 2011 | Hotpoint Ariston WD440G Front Load...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
LG Dryer not Drying clothes
well there must be some problem with the motor engine you should get it checked.
Jul 23, 2009 | LG WM3431H Washer and Dryer
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
Instruction Manual for Hotpoint washer dryer wd420
Try this link:
http://www.hotpointservice.co.uk/hs/pages/manual/manual/search.do
Enter the model number in the search box, and download instructions.
Please rate my solution.
Thankyou.
Mar 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
How do you DRY with the Haier washer/dryer
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Dec 08, 2007 | Hotpoint Aquarius WD640 Front Load...
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
1,089 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
