Question about Kohler 17 kW Emergency Power System - 17RES-L
17 KW Kohler will start and idle but will not step up to proper RPM to run the generator. Is it common for NO gas (Propane) pressure to pass through the regulator when the engine is trying to start. Or does the engine draw the propane that is needed. (There is no-flow through the regulator) Serviceman changed the main circuit board in the unit, and it still would not start and run. Speed sensor checks ok, Throttle Step checks ok.
  • Kohler Master
  • 10,840 Answers
I think the propane regulator is controlled by engine vacuum pressure in a lot of gensets. when was the last time your valve clearances were checked? this is just a thought because if the valves are too tight it may not make the vacuum needed to open the regulator. not sure but its easy to check.
Posted on Jul 08, 2017
3 Suggested Answers
  • 3 Answers
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Posted on Feb 20, 2010
did you put the propane orifis in and unplug the spark wire
Posted on Sep 20, 2010
Generac troubleshooting
please send me more info about this generator I need a model number is this a natural gas or propane I have a neighbor that just had one installed I might be able to get some info from him to help you
Aug 30, 2014 | Generac 17 Kw Air-Cooled Standby Generator...
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
May 28, 2011 | Kohler 12 kW Emergency Power System -...
What is he avrage price of this system
depending on what accessories you get and the fuel type like gas diesel nat gas propane it can run a couple thousand dollars plus the install as well if city permits required it is hard to say hope this helps shop around and have it installed by someone you trust or certified bonded and insured so there is no risk of a home fire good luck.
Aug 28, 2010 | Kohler 17 kW Emergency Power System -...
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Kohler 17 kW Emergency Power System - 17RES-L Logo
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
