Question about Soyo DYLM1998 Monitor
My Soyo monitor (DYLM1998) stays blank (black) except when it is turned on, the monitor shows a picture for 2 seconds and then goes blank again. If I turn the monitor off/on several times, it finally stays on and works correctly. If the computer is left on (I usually turn it off after each use), it will work without fail. I run windows XP with the latest update. It appears to be hooked up correctly. It does not come on when I move the wire in, only when the monitor is turned on, and then only for a few seconds. Any ideas?
    Sergeant:
    Champion:
  • 207 Answers
Your power supply has a short in it this is comon ive seen this before try to replace cord if attatched take it to someone for repairs if not attatched its the cord most of the time loose wire..
Posted on Apr 10, 2011
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
My Soyo 17" TFT monitor comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after about one second each...
Hi
Thank you for your query
Your monitors inverter has burnt out and will need your monitor replacing
I did not even ask for a bid for this as i dont think you should have to pay for a easy solution
Regards
Shauqat
Sep 24, 2010 | Soyo DYLM24D6 LCD Monitor
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Soyo DYLM1998 Monitor Logo
286 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
