Question about Lexmark X2600 InkJet Printer
I got a lexmark X2600 and the paper keeps getting jammed when its inside, im also low on ink may that be the problem?
    Sergeant:
    Champion:
  • 207 Answers
This is common for this printer replace ink reset printer and try new paper,if you believe inks fine try a reset it should realline the paper problem plus check for jammed paper
Posted on Apr 10, 2011
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
Will not print on regular size copy paper paper gets jam to the right of printer but will print an envelop
hi; try cleaning the paper pick roller and the paper guide and check if it has any foreign objects blocking the paper inside the print hope this help, thanks
Aug 26, 2011 | Lexmark X2600 InkJet Printer
I have a Lexmark x2600 printer and when I stated printing many pieces went through and then jammed and won't move in either direction, the paper is really jammed in and I don't see any way to get...
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Tips: Use only paper that is in good condition. Fan the paper before loading into the feeder to prevent sticking together. Use the specified media type and sizes for your model. Don't overload the feeder.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
How do i get jammed paper out of my printer, if i can't get the top open??
Try to open the cartridge area and see if you can get a better hold of the jammed paper. If not, please contact Lexmark technical support for additional assistance.
Feb 10, 2011 | Lexmark X2600 InkJet Printer
Paper jam
Usually ink cartridges get damaged because they get dried up. It usually happens in the areas with low humidity. In that case, you need to add a humidifier to the place where the printer is kept. If the problem still persists, then you may have to replace the ink cartridge.
Jan 19, 2011 | Lexmark X2600 InkJet Printer
I have a transfer paper jammed and can't reach any
Try to open the printer where the cartridges are. You might be able to get a better hold of the paper jammed in there. Otherwise, I suggest you contact Lexmark Technical Support for further assistance. Thanks
Jul 16, 2010 | Lexmark X2600 InkJet Printer
I HAVE A PIECE OF PHOTO PAPER STUCK AND IT WON'T MOVE WHAT CAN I DO
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Lexmark X2600 InkJet Printer
I need to disassemble a Lexmark 2600 (all in one) printer to remove a paper jam. Paper is not visible from feeder or output tray. Is there more than the one screw in the back that I need to remove?
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | Lexmark X2600 InkJet Printer
Keep getting error message when black ink cartridge is in
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
If this does not resolve the issue, please try with a different cartridge.
Oct 18, 2009 | Lexmark X2600 InkJet Printer
I have an x2600 lexmark and it jams the paper everytime I try to print what can be wrong?
there is a piece of paper caught in the gears take a flashlight and find it.
Jul 08, 2009 | Lexmark X2600 InkJet Printer
Lexmark X2600 InkJet Printer Logo
284 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
