Question about HP Computers & Internet
My monitor does not turning on continue blicking green turning yellow what is this?
    Sergeant:
    Champion:
  • 207 Answers
Make sure its plugged into your computer, next it could be your video card second is your have a bad memory card witch is rare.....
Posted on Apr 10, 2011
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
TV will not power on,reset light is blinking and continues after following reset instructings
Probably needs a DM board.This is avery common problem and the board may not be available anymore.Sometimes you can repair them by replacing bad capacitors on the DM board.
Nov 04, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Yellow light of daeth
One thing you can do is try to re-seat the Hard Drive (HDD), there is one blue screw on the side of the ps3 under the hard drive cover,(with the power off) simply remove the screw, remove the hard drive (hdd) and re seat the hdd, if the problem perists contact sony it may be a warranty/recall type issue and they may be able to fix it for you.
Oct 12, 2009 | Sony Playstation 3 (PS3) Console
Tv will not click for pic to show, bulb good, just blicks green
This TV has a Service Bulletin on it that indicates you should install a Ballast Kit.
Also replace the Lamp with a Panasonic Lamp / No generic.If you just replace the Lamp only, it will burn out fast without the new Ballast Kit installed first. Call a good TV tech and have him check for this problem first.
Jul 31, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Jul 24, 2009 | Samsung 226BW Monitor
Ink cartridge problems
exchanged the black cartridge (57): the printer told me there was a problem with it, that I should remove it and re-insert it. I did, the ink button still blicks. After several efforts the printer started to work again, printed one document and then told me there was a problem with the colour cartridge. I removed it, re-inserted it several times. Finally a test page was printed - everything was okay.
Then the printer refused to print anything - the yellow LED lamp blicks continuously. Have turned the printer on and off, have also shut down the computer and re-started.
The only thing that will work now is the black cartridge, if I remove the colour one.
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Samsung color monitor
This problem may arise from monitor as well as from cpu.
First of all check it by unplugging the VGA monitor cable.
This will display the "Check Signal Cable" depending on the model of the monitor. But a message will appear rolling on the screen, if it is not a very old monitor.
If the message is appearing OK and green light is continuously on, that means ur monitor is working fine.
The problem may be with VGA cable or with the booting of CPU and probably the RAM. Recommended solution is to reconnect the RAM and then try, if u think u can do. Otherwise call a hardware engineer.
If there is no message and still the light is turning green and yellow. That means the problem is definintely in the monitor.
Thankyou,
Your well wisher
Nov 27, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
