We have an NEC LCD TV model number NLT-32HDB2. It has been working fine, and I turned it off with the remote last night as usual. This morning the red light below the screen was flashing, and the TV wouldn't start. I turned it off at the wall, waited about 30 seconds and turned it back on. Rather than the single red light, an orange light was flashing, and the TV wouldn't turn on.
  • grahamc5050 Apr 10, 2011
    Thanks for your advice. I have had it turned off now for about half an hour, so I'll turn it back on later this morning and see what happens. However, my guess is that it is a problem with the power supply board, which means I'll need a repairman. :( Thank you anyway for your help.
  • grahamc5050 Apr 11, 2011
    Well it didn't fix the problem but at least we know what is probably wrong and can get a technician in.
  • 6,993 Answers
If your TV won't turn on, then it means it having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
Turn it of at the wall and wait for about one hour again. If that doesn't do the fix, then it is actually having a power problem.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Apr 10, 2011
How do I turn off child lock on my nec tv without a remote ( model: NLT-32HDB2)
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Jul 22, 2016 | NEC Televison & Video
Have a NEC TV Model NLT-32HDI & One For All remote control but none of the code numbers in manual work. Are there other code numbers for this model NEC TV?
try a different remote control unit. Make sure the batties are fresh. Make sure that you are close enough to the tv. Make sure nothing is blocking between the light senser and the remote conrol. Make sure the light senser on the tv is NOT being blinded by direct sunlight. there are normally two ways to program a remote by the manual, one is automatic the other is by code. you could also just order another remote control that came with the tv.
Nov 04, 2014 | Televison & Video
Looking for amanual for NEC RS-32PX tv
The NEC RS-32PX is a remote control. It was included with the NLT-19HDB4 TV. Additional TVs may have come with the remote. The manual for this NLT-19HDB4 is here: http://ernie.awa.com.au/ArticleDocuments/1288/NLT-19HDB4.pdf.aspx with the remote details on page 5 (page 5 of the PDF).
I hope this helps.
Aug 01, 2011 | NEC Computers & Internet
Nec nlt-19hdb3 lcd tv turns on, boots ok, then powers itself off after about 15 secs
Power supply board have problems.Tries unplug,replug the tv an hour later,the tv now,will reset itself back to factory setting.The tv should work now,not than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 11, 2010 | NEC ONYX NLT-19HDB3 19 in. LCD TV
NEC - Model NLT-32HDB2. The DTV (digital receiver) stops working after an hour of use - the television seems to have lost all trace of the DTV settings. The analogue and the other inputs (eg AV HDMI) are...
You can fix this, all that is needed is to carefully understanding the electronics parts used and having little of basic knowledge in electronics.
The problem is in either power supply or the Y sustain board. The Y sustain board is are relatively large board if out of which go connections to the side of the display , it therefore closer to either the left or the right side of the display , has at least one rather large heat sink on it and far power cables connecting it to the mains power supply .
Often there are fuses on that board , one or more , check them
If they are blown you can try to replace them, but expect them to blow again , usually the whole board needs to be replaced.
Often that need to be done in a service center as there are some adjustment to be made after replacement.
Aug 22, 2010 | NEC 19 in. LCD TV
NEC NLT-26HD1 The picture flickers on and off when turning on (cold nights especially) but the sound is ok. And when using tv information/guide and playing games or DVD's.
the main control module has a minor problem and needs to be replaced. eventually you will notice other things start to happen like flashing or colors changing.. take it to a good repair shop...
Nov 17, 2009 | NEC NLT-26HD1 26 in. HDTV-Ready LCD TV
Need code for AUDIOSONIC KGR6 remote for NEC LCD TV Model No. NLT-26HDDV3
try one of the folowing.0028/0033/0037/0044/0168/0184/0711/0742.
Nov 04, 2009 | Televison & Video
No picture no sound
Hi!
It sounds like you have a power supply problem! You will probably find some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain). In addition check the ribbon that feeds the lcd controller.
Feb 19, 2009 | NEC PlasmaSync 42MP2 42 in. Television
Televison & Video Logo
427 people viewed this question
Top Televison & Video Experts
Electro Med Services...
