Question about Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump...
My whirlpool outside jacuzzi is leaking water really fast? it leaks out all the way to the last or deepest part of the jacuzzi
  • 413 Answers
Have you checked for cracks in the fiberglass body?
Posted on Apr 11, 2011
I have a jacuzzi whirlpool tub in my home that has started to leak at the three button control panel. Flooded out the bathroom so I cut a hole in the tile surround and when the pump is running it leak
First thing you need to do is remove some skirting so you can actually see where the water is coming from.
The 3 position control panel would only leak if the water was above it or covering it if it is located in the wall of the tub. That solution would only require the bather to NOT fill the tub quite so full.
IF however the water is coming from another location then that will be noticeable when you are checking for the water leak.
Dec 07, 2014 | Jacuzzi Home
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
My jacuzzi Waterfall faucet drips
Shut water off and remove knobs. Replace valves on side leaking. Go to Home Depo they will help.
Dec 03, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
I have a Jacuzzi Cirrus, bought in 1996. It leaks slowly (I have to fill every 2-3 days. It drops about 8 inches and gets close to below skimmer. Do you know what could be leaking?
Each of the jets have rubber gaskets. The continual heat and cemicals starts to deterioate these and the tub leaks around the jets. This is not always noticeable do to the fact that the water is hot and tends to evaporate. But even a small leak multiplied by all the jets adds up. 1996 is a long time and the replacement of these gaskets are overdue. I hope this has helped it would be the first thing I would look at given the age. Hope this has helped good luck and have a great day. Jeff
Mar 29, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
Jacuzzi Leaking
you need to pull the jet body out and then put some 100% RTV silicone around the jet body and the inside of the wall fitting. Once the silicone is in place re-assemble the jet. that will solve the leak unless there is a broken piece on the jet body or the lip of the wall fitting.
Dec 09, 2008 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
63 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
