Question about Kenmore 63942 Dryer
Wont get hot - Kenmore 63942 Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 11, 2011
Why wont briggs & stratton 173 cc Engine yard man walk behind mower wont start when hot
Try replacing filter element. May swell when hot causing loss of air.
Check with Partstree.com 877-970-2662. They may have an answer for you.
Jul 17, 2014 | Briggs & Stratton Garden
Kurio wont turn on and gets hot
read my other solutions. you have to reset or root the device true the micro SD input. really easy
Dec 27, 2012 | Techno Source Kurio Kids Tablet With...
Wont dry anymore the water is not even hot. water
make sure it is connected to the hot water line, run the hot water in the sink and after hot turn on d/w and make sure it also gets hot. there should be a water line connection from the hot water line normally under the sink and lead to the d/w. should be around 140 degrees
Mar 10, 2010 | Bosch Dishwashers
1997 dodge ram wont start hot, starts fine in the cold but in hot weather needs the throttle pumped and sometimes even that wont do it
What is the condition of the starter ? Is this an engine hard to turn over problem when hot ? If so, the starter might be grounding out, this happens only when the casing is hot.
Jan 18, 2010 | 1998 Dodge Ram 1500 4WD
Hot water wont run out on hot water cycle
You mean Run IN dont you?
Water valve faulty.....replace.
Oct 24, 2009 | Washing Machines
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
