Question about GE Kitchen Ranges
I have a GE Spectra JBP64B0B4WH and recently the lower burner ignited and melted/arced in several places. Do I need to just change the element or is their more to the problem.
5 Suggested Answers
SOURCE: GE Spectra Oven not working
What is "the board"? and is this replaceable by a fairly competent user or does this require a service call? Thanks!
Posted on Feb 07, 2007
reg501
  • 413 Answers
SOURCE: GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Posted on Jun 05, 2008
duby1990
  • 367 Answers
SOURCE: ge spectra jbp64, replacement bottom bake element
Take the 2 screws out of the back wall of the oven (inside) holding the element on. Then pull the element out and it will expose the wires and terminals (2). Unplug the 2 wires and plug them on the new element and mount the element back in the oven and your fixed. (make sure to turn the power off to the oven before you start unpluging wires.
Posted on Nov 21, 2008
MNfisherman
  • 11896 Answers
SOURCE: GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Posted on Jan 20, 2009
REPLACE OVEN DOOR GASKET
Here is the correct gasket to order for that unit. http://bit.ly/Qq3Vp5
Apr 16, 2014 | Kitchen Ranges
Ge Spectra Xl44-three of 4 gas burners will not ignite without a match.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 19, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitors won't work
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Replacing Oven Igniter
PULL OUT THE DRAWER AND THAT WILL ALLOW YOU ACCESS TO THE 1/4" SCREWS IN THE LOWER REAR THAT HOLDS THE BURNER IN PLACE ALONG WITH THE FRONT SINGLE 1/4" SCREW. NEED A FLASHLIGHT FOR THIS. THIS FREES UP THE BURNER SO YOU CAN ACCESS THE IGNITER MOUNT SCREWS.
Feb 14, 2007 | GE Spectra JGBP35 Gas Kitchen Range
Kitchen Ranges Logo
104 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
