Question about Husqvarna Garden
Husqvarna k750 sawing stone starts up fine filters clean stawls under load
  • Husqvarna Master
  • 2,239 Answers
Start by changing the fuel filter in the fuel tank, if this does not help remove the top covers and check the impulse pipe to the carb has not become diss connected, let me know if it still is not right.
Posted on Apr 11, 2011
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
K750 cut off saw three new air filter,gas filter,spark plug saw loses power after 15 sec of hvy cutting
Piston rings are gaulded or stuck, easy to change and fairly inexpensive if you buy aftermarket parts on ebay. I believe piston, rings, and cylinder (if you need it) for less than $100.
Aug 25, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
I have a husqvarna k750 sawing stone stawls under load whats wrong?
If the motor revs up ok it might be the type of disc you are using. I used a huge 2000 Sten one time from about 1961 going through rebar cemented inside cinder block wall to make some windows. It used the huge 18 inch discs and the older guy that was my boss said there is two types of discs - one is tar bonded abbrasives and the other is resin based which is three times better cutting and doesn't smoke up your lungs while you are breathing hard. They are usually dull red with no black in the grit if you look right up close. If the motor stalls or has a cutting out noise at high rev without load it may just be a dust covered gas filter which is deep inside the saw's gas tank on the end of a rubber tube.
Apr 10, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
My k750 petrol saw looses power during cutting
Before taking the saw completly apart, I would check the fuel filter which is inside the gas tank. There is a black hose with a filter on the end of it which lays on the bottom of the tank. the easiest way to get the hose out is to empty the gas out into a safe container. Flip the saw so that it is upside down and grap it with some needle nose pliers. Once the filter is out pull up on the aluminum coupling, this will release the filter. If you do not have a new filter on hand just simply use some carburator cleaner to spray the dirt and slim. There is a hole at the bottom of the filter that will most likely be pluged with slime. Spray some cleaner in the whole and use a tiny flat head screwdriver to clean out the whole. When the whole is free from slime, spray the filter down with cleaner again. This should do it. put the filter back on the end of the hose and fill with gas. Should work perfectly. Keep in mind this is only a temp fix. You should get a replacement filter asap seeming replacing a carburator will be costly.... I hope this helps!
Jan 09, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Saw runs great then bogs down 20 sec. after i start cutting i let off it runs good then bogs again when cutting after a few sec
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Jan 30, 2010 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
137 stalls
Sounds like an air leak somewhere. Or possible a clogged fuel filter.
Mar 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
196 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
