Question about Fisher and Paykel Washing Machines
Washing machine stopped working and started beeping to indicate a fault code 37 what do I do now?
  • 4,399 Answers
Thanks for choosing FixYa and welcome to the site. The code is for a draining issue. You can try unplugging it to reset it first. If not, if it is filled, you will need to drain it. You probably have something blocking the pump. The pump should only have 4 screws to take off. Look there and see if it is blocked. Make sure the drain hose is not blocked also.
Posted on Apr 10, 2011
  • Richard Hale
    Richard Hale Apr 11, 2011
    I have noticed that these washers are bad for lint buildup. I am sure this is what is happening to yours.
Fault code 37
Hello, code 39 is indicating you have an issue with the drain pump. The most common being the pump is failing. If you have been hearing any kind of sqeeking or squeeling or a rattling sound during the wash cycle the pump is failing and will need to be replaced.
Apr 09, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Constant beeping while washing
This can be due to fault within the control panel output to the indication and buzzer. If the washer works without any issue and the cycles are correct, then it is best to remove the buzzer connections as the drive output transistor or IC could be intermittent and so works erratic.
Jul 03, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
GWL11 - Error 37 - Faulty Pump only or Computer/Controller too?
Hi just read your posting.If you are getting error code 37 then the fault is definitely your drain pump.If the pump is getting very hot, it is faulty.What happens is when the pump gets hot the thermal fuse that is part of the windings on the pump opens to stop it burning.I have seen this fault many times and always changed the pump.Hope this helps but please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Our FnP GW611 while filling the water stops and starts and after a short time it stops and beeps and the long wash and spin lights come on orange. Any ideas? Thanks
The problem can be determined through the Wash Progress LEDs. The specific lit LEDs combination indicates an specific error code that tells what generally the problem is. But the exact positions of the lit LEDs are necessary in determining the exact code. Refer to the illustration below and post back the code or the exact positions of the lit LEDs. You may Google for the error code once you determine it, like "Fisher and Paykel Fault Code 37".
Aug 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hi My F&P washer has been doing a error 51 for a couple of weeks, havent had a chance to get someone to kook at it, I stop it and restart it and it washes all the way through the cycle only did this on...
Error code 37 indicates a blocked or not working drain pump but the slight burning smell likely indicates a burned out drain pump motor. Do not use the machine unless the drain pump problem is addressed as it will result in the damage of the motor controller module. It has been found that electrical problem in the drain pump motor leads to the burning out of the motor controller module.
Error code 51 indicates a blocked or damaged diverter valve. It is where the drain pump and the recirculation pump inlet hoses are attached from. It works in directing (diverting) water to the recirculation pump during the wash stage and to the drain pump during the drain and spin stages. Click on the link below for the troubleshooting details of this problems.
Troubleshooting Fault Code 37 on Fisher and Paykel SmartDrive and EcoSmart Top Load Washing Machines
Mar 17, 2011 | Washing Machines
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Nov 30, 2008 | Zanussi FJS1225W Front Load Washer
Fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
